*to clarify
wider in the width between slot
in my case the mill = 0.8mm, forces the slot space to squeeze together when folded
so if you do not need the slot space to squeeze into itself, then i think the milling needs to be larger than the thickness of the board.
then there is the 1 with not enough cut slots, and the entire piece just curves
