It is open for test customers.
They still have bugs to fix, but it is going on really cheap. As soon as my project is working through the little bugs I will keep you updated, as of yet I can tell you:
- Gerber Upload as you know
- then you may enable SMT below where Stencil is also
- there you can select whether top or bottom is to be placed
- then you have to upload BOM and CPL
- youll have to confirm each part, which is nicely made with direct access to the datasheets and basics via dropdown in a table
- then you get a render of your pcb with parts where you can check placement
As of now I have some probs with a bunch of resistors they are working on
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Best regards
Julian
PS: As the Demo seems to be working now, there shall be no need for screenshots?
