Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Rigid Flex with metal Core?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Rigid Flex with metal Core? (Read 2449 times)
mrpackethead
Super Contributor
Country:
D Size Cell
on:
October 16, 2014, 06:54:46 am »
Does anyone know or has seen Ridid Flex PCB's with a metal core ( aluminium or similar? )..
I've got an application that has a bit of heat in it, and i need to get the heat out, but i also want to use flex.
Logged
ruffy91
Regular Contributor
Country:
Re: Rigid Flex with metal Core?
Reply #1 on:
October 16, 2014, 09:27:20 am »
Copper? Has the best thermal conductivity. You can only use a single layer of metal on a flexprint otherwise the layers will tear apart when bending. You can use multiple flexprints over each other but then you will have no thermal conductivity between the layers.
Logged
SeanB
Super Contributor
Country:
Reply #2 on:
October 16, 2014, 05:45:04 pm »
You can have flex boards with a PCB laminated to it. You can get most likely a flex board with the metal plate bonded as well.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
