Author Topic: Inexpensive 4 Layer PCBs with Thicker Copper Layers?  (Read 3908 times)
Offline magicsmokeTopic starter
« on: June 18, 2014, 10:11:51 pm »
I am considering using four layer PCBs as bus bar interconnects for a multi-level inverter.  Most of the relatively low cost 4 layer PCBs for prototyping quantities seem to only offer 0.5 or 1 oz copper layers?  With this copper thickness it is really difficult to keep the trace width to a reasonable value that can be routed.  Any ideas of prototype volume PCB manufacturers which will do thicker copper layers for cheap?
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Inexpensive 4 Layer PCBs with Thicker Copper Layers?
« Reply #1 on: June 18, 2014, 10:20:12 pm »
Any nonstandard options are not going to be available on a prototype  pooling service, so you will be paying all the tooling cost for your panel, so cost for a proto is going to be at least an order of magnitude more than a pooled service.
Day Job: Mostly LEDs
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #2 on: June 19, 2014, 01:17:41 am »
What are you doing with enough current that it can't be routed?  Split the current bearing traces among the four layers, bodge a high current wire or two after, or pay for custom layers.
« Last Edit: June 19, 2014, 01:21:34 am by Rigby »
Offline AlfBaz
« Reply #3 on: June 19, 2014, 01:33:55 am »
Adding solder to unmasked traces on outer layers also helps. Here are some videos
Dave's
Mike's
Offline DerekG
  • Country: nf
« Reply #4 on: June 19, 2014, 02:27:34 am »
If you can, place the bus bar on the bottom layer & open up the solder mask. If wave soldering the thickness will be increased, if assembling by hand use some solder to manually thicken them up.
Buses don't normally push much current. How much are you talking about?
I also sat between Elvis & Bigfoot on the UFO.
Offline peter.mitchell
« Reply #5 on: June 19, 2014, 06:58:28 pm »
Ask in the hackvana IRC channel, he does thicker copper for a small additional cost. http://webchat.freenode.net/?channels=hackvana
Offline IconicPCB
« Reply #6 on: September 30, 2014, 07:12:41 am »
We at Iconic pcb do prototype work. Presently we are making a transformer multilayer structure ( 4 layers) in 0.2mm ( approx 6ounce) copper.
Time to press and fabricate finished board 4 working days ( plating happens at half ounce per 82 minutes).
Cant rush physics..or chemistry for that matter.
www.iconicpcb.com in Brisbane...  beautiful one day... perfect the next
