With linear regulators it's just rampant now. I can't remember the last time I've seen anything in a TO-323 package that wasn't counterfeit. I used to use a lot of LM323's, 78H05's and as replacement parts in pinball machines. Anything available now is usually the cheapest 5v regulator die available, stuffed into the big metal housings, with just some thermal glue holding it down inside the case. Assuming it even works, you're lucky to get an amp of current, where the genuine parts are supposed to be 3A to 5A depending on the part number. Any time you see blue insulators around the legs on something with that style package, run away and don't look back.
