Author Topic: How is your Yamaha feeder doing?  (Read 9396 times)
Offline ar__systemsTopic starter
« on: March 19, 2018, 06:56:07 pm »
I'm having bit of trouble with my Yamaha feeders that I bought from QIHE (so clones, obviously).
1st, I had to install a second spring onto the arm that pushes the peeling wheel against the second one. It was failing to pull the cover tape strong enough without it. So I just bought more of them, and put second one on all of my feeders. So far that created different problem only once, on a 12mm tape. On 8mm tapes it works great.
2nd, I noticed that some of them are more or less prone to components bouncing after the pocket is opened. Some are really bad, some are ok. The problem is critical on 8mm feeders. The temporary fix that I applied wholesale to all of my feeders is a rubber band around the feeder, pushing the top moving plate down. It works pretty well in 95% of times. (Meaning, with the fix I still have a couple of exceptionally bouncy feeders out of 50). I also tried using speed control valve to slow down the feeder. I started with a really bouncy feeder and put LEDs in plastic tapes in it, which is the worst combination. I was able to eliminate bouncing entirely as closed the speed control valve.  However I did not get to deploy this fix yet permanently yet. Need more testing.
Is there any secrets to these that you can share to make things smoother yet?
The following users thanked this post: nikhilrt
Online jmelson
Re: How is your Yamaha feeder doing?
« Reply #1 on: March 19, 2018, 07:57:19 pm »
Yup, I have this problem on certain capacitor tapes, almost exclusively on paper tapes, not the embossed plastic tapes.
Yes, this is why REAL Yamaha/Philips feeders are better.  They have a "vane" or blade that covers the pocket.  This vane moves forward in sync as the tape advances, and is only pulled back as the nozzle is coming down to pick up the part.  I NEVER have problems with the part bouncing out of the pocket with these feeders.
Jon
« Reply #2 on: March 19, 2018, 09:24:35 pm »
Interesting, can you take a picture? Mine also have the blade that covers the pocket as the tape  moves forward. The bouncing occurs when this blade retracts to open the pocket. I could not quite understand whether it from the vibration created by the impact of the fast moving parts, or from the compressed tape springing up...
I'd like to get a real Yamaha feeder to try however not quite sure where to buy them :) They are all "genuine"
Online jmelson
« Reply #3 on: March 20, 2018, 03:46:55 am »
Hmmm, interesting.  I'll see about a photo.  But, my Philips CSM84 weighs 600+ Kg, and the feeder rails are about 20mm thick and solid steel, and weigh about 30 Kg each.  So, the feeders do not bounce, even if you pound on them.  Even though my machine has mechanically actuated feeders (an air cylinder presses down on a lever to advance the 8 ans 12mm feeders) there is no movement or bump to the feeders.  I'm wondering if the actuation of the feeder is causing it to vibrate.  It doesn't take a whole lot of vibration to cause the parts to jump when the cover blade is retracted.
Other than that, the top clamp that holds the tape down fits QUITE tight to the top of the tape.  So tight, in fact, that if the tape is just a HAIR thicker, it will bind the tape.  If the clamp or the blade is not RIGHT down on the top of the tape, it may allow parts to jump out.
Jon
Online jmelson
« Reply #4 on: March 21, 2018, 01:07:50 am »
OK, here's a picture of the tape area of the Yamaha (Philips) mechanical feeder from my CSM84.
« Reply #5 on: March 21, 2018, 02:02:44 am »
Thanks! Well the clones look seem to implement the same principle, but the implementation is slightly different. I also notice that is a section of peeled tape is much shorter than on mine. It looks like if you unload the tape from it you will lose only 4 parts. On mine it will be more. Don't remember exactly, maybe 8. The sprocket also seems to be closer to the pick up location. So maybe that is not exactly a prototype for the Chineese clone :)
Still, I'd like to know if there is a procedure to tune these to work better.
Oh, on your machine, do feeder get a separately regulated pressure? I'm thinking that maybe they don't need full 80-90 PSI and will work better at lower pressure.
Online jmelson
« Reply #6 on: March 21, 2018, 07:37:24 pm »
Actually, with a little technique, you can usually get it down to just a couple parts, although I generally don't quibble over 2 or 4 0805 resistors.
I do get more concerned with several $ op-amps and $0.50 capacitors.  I just about never use cut tape for resistors and small capacitors, just buy a whole reel with leader.  But, I do use cut tape for expensive parts.  For those, I have a technique to peel a little of the cover tape, and then feed the tape into the feeder such that the cover tape catches on the slot where it is supposed to come out of.  This is pretty tricky, but I can get it to work.  Then, I splice the little bit of cover tape that is sticking out to some old cover tape with masking tape, and feed through the puller mechanism.
Well, the little bent blade that covers the next-up pocket really does keep the part in the pocket.  Then, when the feeder lever is pressed, the feeder must not be vibrated.  Even a LITTLE vibration is enough to make the part fly.  That is part of the reason the CSM84 weighs 780 kg or so.
No, the 8 and 12 mm feeders do NOT have any air.  They are mechanically actuated by the same air piston on the head that lowers the nozzle.  The 16mm and up feeders do get air, at constant pressure.  But, the air valve has a "speed controller" that is basically just a needle valve.  I think there's just one needle valve that controls both the extend and retract of the air cylinder.
This is an older style of feeder than is used in the Gem series of Assembleon machines.
Jon
Offline mrpackethead
  • D Size Cell
« Reply #7 on: March 21, 2018, 07:56:28 pm »
I have real Yamaha CL feeders and Chinese Clones, on my YV100's.   The clones work just as well as the orginals.
« Reply #8 on: March 21, 2018, 08:32:05 pm »
So, no malfunction whatsoever? Where did you buy the clones?
  • D Size Cell
« Reply #9 on: March 21, 2018, 10:03:27 pm »
  • D Size Cell
« Reply #10 on: March 21, 2018, 10:04:51 pm »
http://www.ksunsmt.com/
I did'tn say no malfunctions. I just said as well as the orginals.   there will always be something to wrong periodically.     They are mechanical devices. They will break down. But they compare just as well as the orginals..
Offline glenenglish
  • RF engineer. AI6UM / VK1XX . Aviation pilot. MTBr
« Reply #11 on: April 09, 2018, 09:20:43 am »
I also have ksunsmt feeders and they have a sliding vertical tail of metal over the pocket .
Robert did you get your feeder plates changed out, the early TVM920s had those ill fitting feeder plates, the feeders never sat flat and fast on those old plates.
QiHe was swapping them out.
g
The following users thanked this post: mrpackethead
Offline dimbmw
« Reply #12 on: July 31, 2018, 06:40:09 am »
How good is the YV100 ? And how much does it cost? Thanks!
Online jmelson
« Reply #13 on: July 31, 2018, 09:17:34 pm »
YUP, I have REAL Philips/Yamaha feeders, and do something similar.  I just "choke up" on the spring, ie stretch a shorter part of the spring over the points to give more tension.
My real Philps/Yamaha feeders have a blade that covers the pocket as the tape advances.  This blade is retracted when the head pushes down the trip lever, so the nozzle can pick up the part.  Then, the blade extends as the tape advances, preventing the parts from coming out.  This totally prevents parts from bouncing out of the pocket.  See post #4 above in this thread.
Jon
  • D Size Cell
« Reply #14 on: August 01, 2018, 02:26:14 am »
These are 1999 vintage machines,  they dont' make them any longer. You can buy them for around 15-20,000 maybe less if you are lucky.     They are real SMT machines.
« Reply #15 on: August 01, 2018, 02:59:21 am »
It is the same on my clones, but when the blade retracts sometimes parts bounce, especially on plastic tapes. So far I deal with the problem by putting a rubber band over the entire feeder to hold the sliding plate with the blade down. It works.
I actually bought some speed control valves to try and slow down the opening of the feeder, but did not have a chance to try it yet.
Offline dimbmw
« Reply #16 on: August 01, 2018, 05:37:41 am »
Are thre any recent machines that use the same yamaha feeders as QiHe ? Just wondering if we will be able to keep the feeders and use them with the other machine.
  • D Size Cell
« Reply #17 on: August 01, 2018, 09:15:20 pm »
Plenty of machines use the CL Feeders.
Online jmelson
« Reply #18 on: August 01, 2018, 09:39:54 pm »
I got my CSM84 plus about 50 feeders for $3500 US.  Maybe I was extremely lucky (a direct sale, no broker, and yes, the seller was motivated as replacement machines were ON THE WAY).
Jon
  • D Size Cell
« Reply #19 on: August 02, 2018, 12:37:01 am »
Jon
If you hunt around you can find some real bargins.   I got mine at auction, for a song. But it comes with the risk that you have no idea if they are running, and its all on you as-is where-is.
Offline nikhilrt
  • Country: in
« Reply #20 on: October 26, 2018, 12:27:26 pm »
I faced the same issues !
The problem is, you are doing it wrong !
Have a look at the pickup coordinates of the feeder. Is it the one that is generally covered under the metal strip or the one just above it ?
I solved my problem by using the Pickup coordinates to component sitting under the metal strip.
While pickup, the metal strip is supposed to go back and expose the new component for pickup until nozzle picks it up. Once it is picked, the metal strip moves forward (back to its original resting position) moving the next component forward under it. (The next component will never move as it is protected by the strip).
If you set the other coordinate, when tape is moved forward, since the component is left open, no one is stopping it from moving / overturning / rotating.
Online jmelson
« Reply #21 on: October 26, 2018, 10:41:14 pm »
Yes, look at my picture in reply # 4.  The location to pick up the part is where the tip of the cover blade is.  When the feeder is "activated" that cover retracts, exposing the part, but NOT advancing the tape.  Then, when the feeder is "released", the cover slides forward at the same time the tape advances.  So, the next-up component is covered by the blade until the nozzle is right over the pocket to pick it up.  Unless the feeder is jostled a lot, the parts will not fall out.
Jon
« Reply #22 on: October 27, 2018, 11:54:36 am »
Congrats on figuring out that the pick up coordinates should be for the part under the blade! It is so self-evident, I'm sure you are the only one that made this mistake.
Offline AJ Quick
« Reply #23 on: November 27, 2018, 04:40:29 am »
Have you had any luck trying the regulator / speed control valve?  Likewise, I think the feeders have way too much pressure and that's causing chips to jump! I'll try the rubber bands on mine!
« Reply #24 on: November 27, 2018, 03:32:58 pm »
I did one experiment but never gotten to implement it on all of the feeders. I keep using rubber bands. They break, but they are cheap and easy to replace. I'm not sure why, but the jumping behavior nearly disappeared for me. Maybe the feeders kind of broke in? Recently I was making 64 boards with a total of couple of 1000s of 0603 LEDs in plastic tape(aside other parts), which used to be real PITA, they were bouncing real bad. And I don't remember having any of the LEDs upside down.
I'm not sure if the s/w on your machine allows per feeder pickup z adjustment, on mine it does not. I lowered feeder plate on one side by about 0.8 mm, and use this side for paper tapes only. The other side (higher) is used exclusively for plastic tapes. In yamaha feeder the optimal pickup height depends on tape thickness, and this trick allows me to keep it closer to optimal to different types of tape.
