Hi All,
I recently tried stencil soldering my projects in the hope that it would save me time compared to hand-soldering, what I am used to doing for years. However, i am running into problems, and I am wondering what I am doing wrong. The biggest issue that I keep having is that the solder paste spreads between pads. This way, after reflowing, all the pads are soldered together, and it takes me more time to rework/troubleshoot the boards than it would have taken if I just soldered by hand. I have added an image of one of my solder paste applications as an attachment. I re-pasted the board a couple of times already before the foto, so therefore some holes are also filled with paste. This is no problem. The problem is more with the SOT23-6's and the QFN in the middle, where all the pins will be one clump after soldering. It is a 0.4 mm pitch, but that should not really be an issue, should it?
My method is as follows:
I clamp the board to be soldered on all four sides with other PCBs, so the stencil can lay flat.
I align the stencil on top of it
I tape the stencil down as well
I apply the paste
I remove the tape carefully
I lift the stenil up on one side, until it is almost vertical and then lift it away
What could I do differently?
