Author Topic: Paste flux  (Read 2416 times)
Offline ramicioTopic starter
Paste flux
« on: April 18, 2013, 02:09:26 pm »
Radio Shack only has paste flux in store, not the pens of the clear liquid.  Can I use the thick paste to reflow?  I just want to use it on something already soldered to break the surface tension and try to make sure there are no shorts by heating it again.
Offline MacAttak
Re: Paste flux
« Reply #1 on: April 18, 2013, 02:23:27 pm »
You can probably order a pen of fresh high-quality flux and have it shipped 2nd-day more cheaply (or close to it) than the crap they sell at Radio Shack these days. For most tasks, Kester 186 works really well and is a widely recommended brand - and sells briskly enough that you don't have to worry about it being old.
Re: Paste flux
« Reply #2 on: April 18, 2013, 02:35:04 pm »
I guess I will just go on eBay and order a pen of that flux from the closest seller.  Thanks!
Offline nanofrog
Re: Paste flux
« Reply #3 on: April 19, 2013, 04:15:50 am »
You can also get liquid flux in small containers (i.e. MG Chemicals sells rosin flux in 125ml and quart containers), and put it into pens yourself.
Refillable Pens (2 pk). http://www.mouser.com/ProductDetail/Chemtronics/CW7000/?qs=sGAEpiMZZMvNdIckKBEZymSxungURxcGQVUERwq7bgs%3d
Flux http://www.mouser.com/ProductDetail/MG-Chemicals/835-100ML/?qs=%2fha2pyFaduipqzzCukZ5o35Qp8FqqkB6wc%2flCZeM4dI9eYbNQacwAAHMN7wykWNsLp7jxNDXWxA%3d
SRA also sells a refillable kit as well (link is rosin, but they also have other formulations if you prefer) http://sra-solder.com/product.php/7048/141/sra_99_20_rma_rosin_flux_pen_with_5_refills
Cheaper than buying disposable pens, and still end up with excellent quality supplies.
Re: Paste flux
« Reply #4 on: April 19, 2013, 04:59:09 pm »
Thanks for that.  I don't do enough of this work to need that much.  If by some miracle people started getting interested in the stuff I make then I might need more volume.
