We need to heatsink the two TO220 FETs of a 90-265VAC, 130W Two Transistor Forward.
We wish to have them both screwed to the same aluminium block.
The block will be 16mm x 11mm by 25mm high.
The FETs will be screwed on the two 25mm by 11mm faces. (The TO220 FETs will be vertical against the opposite faces as described.
This will be a custom heatsink, as there is nothing offtheshelf.
How much do you think it would cost to make this?
In quantities of say 5000?
It will have a M3 hole right the way through for the screw to which the tab nuts will be screwed on.
So that screw has no head as it will have a nut each end. (the hole is not tapped)
