Author Topic: Glue to temporarily attach thermocouple wire to fixtures?  (Read 3512 times)
Offline julian1Topic starter
« on: September 21, 2020, 01:38:41 am »
Kaptan tape works to a point.
But are there any glues available, that could withstand higher temperatures (up to 300C) , and could also be easily cut away or removed with common solvents (isopropyl/ acetone). Maybe silicone based or rubber-like plasticity with some give.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Glue to temporarily attach thermocouple wire to fixtures?
« Reply #1 on: September 21, 2020, 02:31:32 am »
Not sure about glue, but why not use a washer/eyelet thermocouple like:
https://au.rs-online.com/web/p/thermocouples/2000615/
Offline SMTech
« Reply #2 on: September 21, 2020, 09:38:10 am »
If you are using them for profiling, the other option is to solder the thermocouples in place using high temp solder, there are several with melting points around 300C which is way past anything you should see when reflowing SN100 or SAC.
« Reply #3 on: September 21, 2020, 10:32:01 am »
I'm interested in attaching to boards, so the mechanical strength needed is almost nothing. Anything ghetto style would work. I was thinking about modelling clay, but figure there must be something better.
Offline Kleinstein
« Reply #4 on: September 21, 2020, 05:05:32 pm »
There are high temperature cements. There may be not easy solvent, but the mechanical strength and adhesion to metal is usually poor. So it can usually be scraped off and small residue may be removed with acid.  The is also sodium silicate solution, but here is may be a little more tricky to remove.
Offline Mangozac
« Reply #5 on: September 21, 2020, 08:34:42 pm »
We just fasten the wire in place with some kapton tape and put a dob of heat transfer paste where the thermocouple tip touches the PCB.
Offline elecman14
« Reply #6 on: September 21, 2020, 08:47:36 pm »
Could you use peelable solder mask? Seems like that is used for component adhesion in some applications.
Offline pickle9000
« Reply #7 on: September 21, 2020, 08:55:55 pm »
High temp RTV silicone (red) in an automotive store.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #8 on: September 21, 2020, 11:07:35 pm »
This will work for a bit, but after X many thermal cycles your paste will dry out and make an air cavity between the tip and board, which will eventually lead to underestimated temperature readings
Offline pickle9000
Offline Mangozac
« Reply #10 on: September 22, 2020, 03:01:50 am »
Yeah, that's why it's only a temporary solution ;)
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #11 on: September 22, 2020, 03:56:44 am »
Oh lol, completely missed the "temporary" part from OP...
Offline CatalinaWOW
« Reply #12 on: September 22, 2020, 04:17:04 am »
All temperature readings must be regarded as estimates.  The thermocouple, its wires and any hold down material modify the thermal paths.  If you really need to know the precise temperature it requires a lot of thought and thermal modeling.  Or perhaps remote sensing with a pyrometer or thermal camera.  Those options don't modify the thermal environment, but tend to be lower precision.
Drying thermal paste can lead to either high or low temp estimates, depending on which side of the thermocouple the air gap forms.  And can lead to low estimates early if the thermal paste acts as a spreader.
