Author Topic: Gerber File Viewer  (Read 1376 times)
Offline AttorneyTopic starter
Gerber File Viewer
« on: August 29, 2020, 02:49:00 am »
Any suggestions for a standalone Gerber File Viewer?  I need to print a PCB board image to paper and use it as a drilling template.  So, it will be important that the printed image is very close to 1:1 accuracy.
Paul
Offline greenpossum
Re: Gerber File Viewer
« Reply #1 on: August 29, 2020, 04:39:05 am »
Operating system?
Offline AndyC_772
« Reply #2 on: August 29, 2020, 06:26:18 am »
The following users thanked this post: Attorney
« Reply #3 on: August 29, 2020, 11:35:52 am »
Many thanks, gerbv worked well.  The image printed slightly smaller than the PCB.  To get the exact size, export the print to a PDF file.  Open up the file in Adobe Acrobat, and adjust the scale in the print settings menu until the board fits precisely on paper.  In my case, it was 102%.
Paul
Offline phil from seattle
« Reply #4 on: August 29, 2020, 08:53:28 pm »
That is probably the fault of your printer and driver, not the gerb viewer.  Note also that the paper and humidity level play a part in this as well. Even the handling of the paper can have an effect.
