Author Topic: Reflow oven for home use  (Read 16560 times)
Online tggzzz
Re: Reflow oven for home use
« Reply #25 on: June 06, 2015, 05:46:51 pm »
While heating the fan is not used.
I didn't realise turning the fan off was an option; when thinking about using it to cook food (!) I decided that the fan would be essential.
In which case I would question the evenness of the heating and whether or not tall components would produce a shadow, or thick components delay the heat reaching the solder paste. At least with a saucepan+sand the heating is even and traverses a uniform thickness (1.6mm) before getting to the solder paste.
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« Reply #26 on: June 06, 2015, 06:20:38 pm »
I was refering to the T962 not the food cooking oven perhaps i misunderstood.
Offline zapta
« Reply #27 on: June 06, 2015, 07:08:55 pm »
The 2 temperatures are displayed during the process and often there is as much as 12° between them but they are equally spaced from the centre and they are on the same line in between the 2 heater elements so I can't really see why they differ so much presumably it's a calibration problem.
Mine also shows two graphs and I always assumed that one is the target temperature and the other is the actual.
  • Global Moderator
« Reply #28 on: June 06, 2015, 09:59:37 pm »
There is also an actual readout of current temperature next to the graph. on mine the expected graph is shown and gradually replaced with the actual temperature points measured. so I don't know, maybe one of those measurements is expected and the other actual but there are two probes hanging in the oven chamber
Offline DerekG
  • Country: nf
« Reply #29 on: June 06, 2015, 10:04:21 pm »
I wonder if it would be worth placing a sheet of alfoil on top of the sand? This would keep the sand from touching the bottom side of the board.
I also sat between Elvis & Bigfoot on the UFO.
Online tggzzz
« Reply #30 on: June 06, 2015, 10:32:32 pm »
Possibly, but it might introduce other effects. It would reduce the probability of a few grains of sand getting onto the top/component side of the board. They can be brushjed off and don't cause any problem, but it is fundamentally inelegant.
