Noob question:
As I understand it, this machine will just pick and place.
So please explain:
1) How do you setup the source of the components? How does the machine know where each resistor, etc. are positioned in the "stock"?
2) The machine then picks the component and places it on the correct position. But how is it then soldered? With just a slight blow of air (for instance from the head moving nearby when placing some other component) a small resistor could be dislocated, I would imagine.
Kind regards,
Vitor
