Author Topic: Do you use teardrop in PCB layout?  (Read 199 times)
Pinkus, kylehunter and 4 Guests are viewing this topic.
Offline Wilson__Topic starter
« on: Today at 03:58:50 am »
Do you use teardrop in PCB layout?   If so:
Where you use it, PTH pads, Vias, (may be not) SMD pads, Track to track?
Do you use it only on default 0.2mm signal track width (and not on wider power tracks)?
Many thanks
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Do you use teardrop in PCB layout?
« Reply #1 on: Today at 05:53:11 am »
I use it on production designs, on request.
Altium's automatic generation seems good enough, and I haven't heard any push-back from it.  Mind, production may optimize the design further after I'm done with it.
It's not very meaningful for proto designs, if that's what you're doing.  It's a production yield optimization -- or, if your footprints (mostly thru pad annular rings) are so insufficient that proto yield even is poor, you should probably address that first(!).
Seven Transistor Labs, LLC
« Reply #2 on: Today at 06:07:13 am »
Apparently, pcb factories are quite good since usb-c and 0.5mm IC are widely used nowadays.
KiCad defaults to no teardrop for 0.2mm track width.  May be suggesting no teardrop???
Offline shabaz
« Reply #3 on: Today at 06:39:18 am »
I tried the teardrops feature in KiCad for the first time the other day. I did it for no reason other than just curiosity.
The attached screenshot shows the KiCad config I used for the through-hole pads for a typical 0.1" pitch pin header; you can see the result in the photo (JLC PCB).
« Last Edit: Today at 06:42:59 am by shabaz »
Offline screwbreaker
« Reply #4 on: Today at 06:48:00 am »
I do, even in prototypes if I can.
It makes the junction between tracks and vias more reliable, especially when you start soldering on it.
On prototypes often you have to solder/desolder stuff many times, and a tiny track can easily break, with a teardrop it became more robust.
The only downside, when I used it on altium, is that you have to remember to regenerate them every time you do some change on the PCB. Otherwise you can end with random poligons here and there.
