I tried to solder (reflow) an 8 pin device 2x2mm (only pads underneath, not visible from the side). Stencil and PCB from JLPCB. I do not have a stencil printer, so taped
the PCB and the stencil to apply the paste. I have tried over 10 times, but whatever I do I always get too much paste, bridging 2 pins.
I used the squeegee only a single pass without applying too much pressure, but still too much paste.
For next time, reduce your stencil apertures a bit, since doing it by hand tends to result in more than desired.
But for this one you have now: I’m concerned about your statement “without applying too much pressure”, because you fundamentally want a fair bit of pressure so that the stencil is wiped completely clean by the squeegee. The idea is for the paste to fill the holes and be scraped level with the top of the stencil, and for the stencil to be in perfect contact with the board so that nothing squeezes out. And you want this to occur in
ONE pass! DO NOT make multiple passes, as this results in smearing the paste underneath.
A soft squeegee (like a credit card) can seem more forgiving, but IMHO is harder to use because the pressure applied is inconsistent across its width. A metal putty knife is often a better choice, but the very best squeegee I’ve used is one a coworker made himself out of two layers of old stencils. He took two of them, with their razor sharp edges, and laid them on top of each other, sandwiched between two 2mm aluminum sheets as a handle. The stencils stick out different amounts (approximately 6mm and 9mm) so that one is the actual squeegee edge, the other simply provides some support so it doesn’t flex too much. See img_3336.
Img_3338 shows how to use the homemade squeegee, and what happens when you use it, and what happens if you go over it again: the stencil will lift a bit after the first pass, and if you press it down again, the paste will smear a bit. That smeared paste now acts as a spacer when you press down again, so the second pass will force paste under the stencil.
Also, 0.25mm apertures are quite small, so this is a situation where a finer paste (T4 or T5) might make sense.
