if I remember correctly, the schematic library makes a file and one big file. So if you have resistors library, all resistors go in one big file? if that is what they are changing, I am all for it. Also, they should change how schematics reference things. Instead, it should just make a local copy. Nothing sucks more than having someone change something in a shared library and having it resonate to an older design.
