Author Topic: QFN/VQFN work  (Read 8582 times)
Offline SiliconWizard
Re: QFN/VQFN work
« Reply #25 on: April 24, 2019, 02:50:53 pm »
If the packages have an exposed pad, and if you haven't already, check whether some pins are shorted to ground (which is probably what the exposed pad is connected to). If so, you'll have a very hard time getting rid of the shorts with just some manual touch-up.
The solder paste mask matters. Is your exposed pad area in the stencil a solid square, or is it several smaller squares (as shown here: https://www.allaboutcircuits.com/technical-articles/stencil-design-for-exposed-pad-packages/ ) The latter is a much  better approach to avoid shorts and flatness issues.
