We received the machine today, first run will be tomorrow. After that I'll write more.
Right now it seems OK for the price.
The build quality is OK, nothing special. It was cheap and it has some cheap build choices.
For example there is no oil lubrication in the compressed air line. But it seems to me that it is necessary for the feeders, so I'll have to add one later.
They gave a jar of grease for the machine... I did not found yet the greasing points, it seems odd.
The timing belt (or I don't know which is the exact word in english) also seams cheap. We received spare parts, so I'll check it later.
Otherwise the machine works out of the box. The manual is OK except it seems impossible to start the first run based only on that
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
But the support is really good, we received several youtube links. And they are available a lot on skype also.
The display is way too small for my taste, but it has no effect on the usability of the machine.
It is hard to use the touch display for fine movements, but in the regular use there is no need of that, so I can live with it.
If everything goes well, it will use it in production next week, so I'll have actual info of the speed of the machine.
