Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Manufacturing & Assembly
Conformal coating
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Conformal coating (Read 940 times)
stoyanoff
Contributor
Country:
Conformal coating
on:
February 28, 2021, 07:53:19 pm »
Greetings! I have a high voltage PCB. And I have a problem with the necessary clearance. I want to use a sensor in SO-8 package, but the distance between the rows of pins in this package is too short. The distance is 5.8mm and the needed clearance is 7.1mm(550V). So I want to add a slot beneath and to cover it with somekind of conformal coating. Can use just acrilic(or silicone if it is better for high voltage protection) coat spray or I need to cover it with rubber like rtv11?
Thanks!
Last Edit: February 28, 2021, 08:09:21 pm by stoyanoff
Logged
Rat_Patrol
Frequent Contributor
Country:
Re: Conformal coating
Reply #1 on:
March 01, 2021, 10:40:38 pm »
Proper spacing rules notwithstanding, I would use epoxy and get it on thick. I don't see how you could sell such a project though. At least in the USA, the first time failure occurred, the lawsuits would start coming in.
Logged
penfold
Country:
Reply #2 on:
March 01, 2021, 11:03:22 pm »
Are you intending to sell it?
Where did you get a 7.1mm clearance from? Is it mains? AC or DC?
Conformal coating only strictly reduces your pollution degree for creepage rather than giving you any additional free clearance, potting would be the way to go in you really need to do so for a production
Logged
stoyanoff
Contributor
Country:
Reply #3 on:
March 04, 2021, 01:43:51 pm »
Yes! Potting will be! I`ve changed the construction and I put the problem part on a separated PCB. So now I can cover it with some resin and decrease the polution level. So this will allow me to meet the parameters with lower clearance. And also device could be repaired if it is needed.
Thanks!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Conformal coating
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
