Author Topic: Ersa i-CON pico anti-static mod?  (Read 3656 times)
Offline KarelTopic starter
« on: December 03, 2022, 10:21:25 am »
I'm considering to buy an Ersa i-CON pico but I would like to know if it's difficult to connect the iron to ground using a 1 meg resistor.
Even if the powercord doesn't have a ground terminal, I'm thinking of adding a banana jack in the enclosure which is connected to the iron via a resistor.
Before buying I would like to know if one of the wires in the cable between the station and the iron is connected to the metal
part of the iron.
Edit: I found the answer here:
https://www.eevblog.com/forum/projects/grounding-the-tip-of-an-ersa-i-con-pico/
https://youtu.be/ZT8HsC8ewzc
« Last Edit: December 03, 2022, 04:55:22 pm by Karel »
