Author Topic: 10000CPH real mounting speed Tronstol A58 4 heads PNP machine with flying camera  (Read 1133 times)
Offline Jemma.zhangTopic starter
  • Country: cn
Real flying camera, picking materials and shooting at the same timeļ¼šhttps://youtu.be/lBpdrYk-K7o
I couldn't imagine that the 4-heads PNP machine could have both speed and precision.
10000CPH real mounting speed Tronstol A58 4 heads PNP machine with 58mm*8mm
Neoden 4- 4 heads: Real mounting speed 3000CPH
Neoden S1/Tronstol A1-4 heads:Real mounting speed 3500CPH
Neoden 9-6 heads:Real mounting speed 7500CPH
Neoden K1830-8 heads:Real mounting speed 10000 CPH for LED
The speed of TronStol A58 4 heads is similar as the 8 heads PNP machine.
Continuous technological innovation to surpass our past selves.
Cost-effective models to meet your needs for price, speed and accuracy :)
Online jmelson
Very impressive!  I don't see where the cameras are located on this machine.  How do they work?  Looking down from above the component?  Sight across the component, like my Quad machine with QuadAlign cameras?  Just curious.
Thanks,
Jon
  • Country: cn
This video is showing you where is the camera:https://youtu.be/M-BKYktPNh8
It install on the mounting head,you can check the picture :)
Online jmelson
Fascinating!  Thanks for the info.  It seems a bit like my QuadAlign  cameras, but quite a bit more compact.  20+ years of progress!
Jon
