Author Topic: How do we check IC on the PCB working or not?  (Read 11800 times)
Offline aarvyTopic starter
« on: July 07, 2014, 05:28:33 am »
Hello,
How can I check that some ICs on PCB works properly or not? Can I turn off the power supply and then by giving necessary inputs and checking outputs? My PCB contains ARM Processor and few Op-amp ICs. I need to check Op-amp IC. I do not have any other testing equipments.
Offline David_AVD
Re: How do we check IC on the PCB working or not?
« Reply #1 on: July 07, 2014, 05:40:13 am »
Wave a dead fish over it?   ???
I think you'll need to supply more details to get a sensible answer.   :)
Offline Skimask
« Reply #2 on: July 07, 2014, 05:44:18 am »
oooo.....  I like that.  Going to try that next time I've got a problem.
 :-DD
Now...where to find dead fish....
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
« Reply #3 on: July 07, 2014, 05:53:42 am »
Well, PCB has few ICs ( Op-amps, Driver, Voltage regulators etc). Now I want to check the IC is in working condition or not.
Problem: IC is already connected to other ICs on the board. If I will give some INPUT to IC and then check OUTPUT of the IC, can I check this way? ( What if current would flow from this IC to the other part of the PCB ?!  ??? )
Offline tautech
« Reply #4 on: July 07, 2014, 06:01:32 am »
You could try the "razor blade" technique on individual IC's.
Slice signal path tracks (in & out), provide test signal and measure output.
Solder over slice when the problem is fixed.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #5 on: July 10, 2014, 06:59:22 am »
Usually something like this is taken in to account when designing the prototype. Putting resistors/jumpers on lines so you can desolder them and feed a different signal. Also putting in a ton of test pads never hurts.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline rob77
  • Country: sk
« Reply #6 on: July 10, 2014, 07:09:19 am »
 :-DD
i think the best source for extremely dead fish is this  :-DD (extremely dead - judged by the smell (stench?) )
http://en.wikipedia.org/wiki/Surstr%C3%B6mming
but to the OP's question - just measure the in/out voltages of the opamps in-circuit  and compare the readings to the expected values.
Offline owiecc
    • Google scholar profile
« Reply #7 on: July 10, 2014, 07:15:19 am »
Turning the power on helps with debugging. Checking an opamp is quite straight forward. Check if correct voltage is present on power pins. Locate the inputs and check if the voltage difference is zero with a multimeter. Check also is input voltages are within the acceptable range.
Offline Bassman59
  • Yes, I do this for a living
« Reply #8 on: July 10, 2014, 09:29:31 pm »
Hello,
Well, if you want to test an op-amp, the usual thing to do is to give it an input signal and look at both the input and the output on an oscilloscope.
Offline jamesglanville
« Reply #9 on: July 10, 2014, 10:24:56 pm »
Can you not just write some test code to run on the ARM? It should be quite possible to get the ARM to send a range of signals to the opamps and then probe the outputs with an oscilloscope.
Offline David_AVD
« Reply #10 on: July 10, 2014, 10:44:23 pm »
The OP is possibly another "post and run" guy.  No easy instant result and they haven't been back since the day of posting.  Seems to be a few of those lately.
Offline Bassman59
« Reply #11 on: July 11, 2014, 09:44:41 pm »
He got an answer he didn't like. He did say, "I do not have any other testing equipments," and of course every reasonable response said, "Look at it with your oscilloscope."
Offline Skimask
« Reply #12 on: July 12, 2014, 03:37:13 am »
"a few" is the understatement of the year! :-DD
I turned it on.
Offline Smokey
  • Not An Expert
« Reply #13 on: July 12, 2014, 05:27:25 am »
This is assuming NO other equipment....
Test #1)  Visually inspect.  Does it have a big hole burned in the top of the package?
Test #2)  Touch test.  Power up the board and tough the part with your finger.  Did it burn the hell out of you?
Passing these tests doesn't guarantee a functional part... But failing them is probably a bad sign :)
