Author Topic: Round project enclosure Manufacturers?  (Read 7902 times)
Offline Sciguy75Topic starter
« on: April 01, 2012, 05:43:37 pm »
Hi everyone!
So glad that i found this site.  I was looking through the enclosure manufacture posting and couldn't seem to find what I am looking for.  I was wondering if anyone knew of any manufacturers that make product enclosures that are round? I notice that most seem to be made into rectangles or square shapes.
I am working on a electronics prototype requires a round enclosure approximately 25mm in diameter or less and approx. 15mm in height or less. The material that the enclosire is made out of isn't as important as shape of the enclosure itself.
Any suggestions would be greatly appreciated
Thank you!
Offline slateraptor
Re: Round project enclosure Manufacturers?
« Reply #1 on: April 02, 2012, 07:54:23 am »
1) Look around for general purpose tin cans,
2) have a custom sol'n manufactured,
3) reconsider your design goals.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: April 02, 2012, 01:11:21 pm »
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #3 on: April 02, 2012, 01:43:48 pm »
Shop any store that sells womens makeup and just look at the containers.  There are many that are in the size you describe.  Buy the cheapest one that fits the bill for color, material, and size and dump the contents.  If your country has dollar stores it will only cost you a dollar per container.
Offline sacherjj
« Reply #4 on: April 02, 2012, 01:46:28 pm »
I picked up some screw together round containers about that size as a set in the beading isle of our WalMart.  I use them to keep small electronics pieces, such as 0.1" jumpers, etc.  I believe mine are a little shorter than you want, but there were many varieties there.  I would try whatever hobbyist or sewing stores you have around.
Offline robrenz
« Reply #5 on: April 02, 2012, 01:53:57 pm »
Edit your profile to show your country so people can better answer your questions based on location.
  • Country: my
« Reply #6 on: April 02, 2012, 02:16:19 pm »
since you've made the suggestion. so this link...
https://www.eevblog.com/forum/projects-designs-and-technical-stuff/idea-alternative-way-of-quick-cheap-and-easy-product-enclosure-supplier/new/#new
with the above advice, showing your country is irrelevant. :P
Offline Spawn
  • ³²µ º'ºººº³²
« Reply #7 on: April 02, 2012, 11:22:11 pm »
I am not sure if I understood you good, but do you look for something like in the photo below?
It is Ø 26 x 17.5 mm not exactly the measures you want but pretty close.
Click on the image for the vendor
