Author Topic: Chemtronic flux-off spray brush is ESD safe?  (Read 921 times)
Offline FaringdonTopic starter
« on: July 07, 2021, 11:44:16 am »
Hi
This Chemtronix “Flux-off” spray has a brush on its nozzle….do you think its ESD non-generative to brush over components after spraying them with the “flux-off”?
http://www.farnell.com/datasheets/2692996.pdf
'Perfection' is the enemy of 'perfectly satisfactory'
Offline thm_w
  • Non-expert
Re: Chemtronic flux-off spray brush is ESD safe?
« Reply #1 on: July 07, 2021, 09:14:13 pm »
Visually it does look like it: https://tmelectronics.ru/product/CH-ES830BE/ but they don't tell you.
If you are working on something super sensitive to ESD I would get a proper esd safe brush and then add a wrist strap. For normal electronics that thing will be fine.
The following users thanked this post: Faringdon
« Reply #2 on: July 08, 2021, 06:06:41 am »
Thanks i just brushed over a 12MSOP pwm controller IC with it...i hope it will be OK
