The best you can do is get rid of it. It's a complete trash, worse than cheap Chinese ovens. No proper temperature increase curve control, no reasonable temperature uniformity. Unless all you want is reflowing small boards, parts of the PCB will be overheated while the rest barely above solder melting point. Also there is no consistency between the runs whatsoever.
