Author Topic: higher quality crimp terminals (brands?)  (Read 4217 times)
Offline deadlylover
Re: higher quality crimp terminals (brands?)
« Reply #25 on: August 19, 2024, 12:40:40 pm »
Thanks for explaining the benefits of the PIDG terminals. Do they really need the special crimp tool from TE, or can they be crimped using generic tools meant for insulated terminals?
Ehhhhh the "correct" answer is always the tool and the terminal must be matched. In my experience the PIDG are ok with normal tools, but TE's ultra-fast faston terminal line just doesn't work at all so don't accidentally buy those (they have a flat edge on one side so it doesn't work with generic tooling).
When I pulled them both to failure, the Pressmaster failed at the strain relief while the AMP failed somewhere in the main crimp (does that mean with vibration and age the Pressmaster will fail earlier, who knows). I can't remember the numbers off the top of my head but both of them were way over the mil-spec tensile strength, it was really uncomfortable pulling ~35kgf on 16 AWG wire, and the strength is basically the same as the wire only without any crimps.
Pictures are a PIDG red terminal 320559, looks pink in my photos. I managed to buy a couple hundred terminals cheap on eBay so I'll have to do a bit more experimenting for science...I just hate "wasting" them ahahah.
Offline bostonman
« Reply #26 on: August 19, 2024, 01:23:40 pm »
I’m still kinda surprised, and still suspect they were not crimped correctly.
I agree that if crimped correctly, it should be solid. Most likely the best way to crimp in this case would be a crimp in the middle of the terminal cup so the end of the wire is flared and can't pull out beyond the crimped metal. Those Anderson connectors were quite tight though. It took quite a bit to disconnect them, so add several feet of wire, someone yanking on the wire with an instantaneous force, etc...  and they'd pop out.
Technically speaking though, over time, doesn't the wire/connector develop corrosion, and, as the wire wiggles (say due to many removals), the connection becomes intermittent?
Over the years I've seen various connector type failures. One was gold pins on a connector that when soldered on the PCB developed (per the term used at the company) gold embrittlement in the solder. This (and maybe a combination) of the female connector having non-gold contacts caused the voltage to vary. This varying voltage caused alarms in the unit because it would sag beyond the firmware alarm trip point.
For the most part though, any connector that has properly crimped pins should last, so I don't disagree. I just see crimped pins and the first thing I think of: this is another failure point and I can eliminate it by soldering the crimps.
Offline Kjelt
« Reply #27 on: August 19, 2024, 02:06:07 pm »
AFAIK keeping the crimp as the same sorts of metals as the wire with about the same range of electrode potentials will not give problems unless very humid environments.
Just the opposite, soldering with flux inclusions and different added metals are prone to corrosion.
Or you design for more than a few removals and then use the appropriate connectors and shielded/isolated cables with mechanical strain relief (example sud-d connector housing with crimped contacts) OR you remove the connectors on the connector itself not by pulling the wire(s) even when the crimp does provide a form of mechanical strain relief on the isolation of the wires.
Offline bostonman
« Reply #28 on: August 19, 2024, 02:35:39 pm »
Everything is prone to failure though due to time. Soldered wires to PCBs versus connectors and they develop cracks in the solder.
For the record, I don't disagree with anyone. Properly crimped pins, proper insulation, etc... is key.
I've worked on stuff and disconnected connectors numerous times and been amazed at how they've held up.
Offline tooki
« Reply #29 on: August 19, 2024, 06:33:47 pm »
Well, I wouldn't call that unavoidable. There are numerous other ways to deal with it. See e.g. https://www.newenglandwire.com/litz-wire-termination-guide/
I'm well aware of New England wire, we use their litz wire very often and consult with them on our process. I believe the non-solder termination processes are for very large wire diameters (like 0 AWG) with very large strand sizes (like 20 AWG) and low strand counts. For fine strands (40 AWG and up) there's no reliable alternative to soldering.
Chemical, flame, or salt stripping? Soldering isn’t the only non-mechanical way to strip.
I wouldn’t be so sure that the other processes are only for large wire anyway, unless the respective manufacturers say so.
And if you absolutely have none of those alternatives available, I'd sooner solder (only) to the crimp terminal than to crimp to solder-tinned wire.
In theory this might be feasible but you'd have to dip the entire terminal in the solder along with the crimp, which might cause other problems. Might be ok for basic ring or spade terminals, never tried it.
Who said anything about dipping the terminal?!! :o
You’d use a solder bath to tin the wire, then solder it into the terminal. Like with a soldering iron.
I've also wondered if soldering the litz wire into a ferrule and crimping to that would be the best compromise. Asked NEW about it and they basically said "interesting, give it a try and let us know how it goes".
That would give me the heebie-jeebies. It basically sounds like you could easily end up with a fractured solder joint within the ferrule.
Offline tooki
« Reply #30 on: August 20, 2024, 12:13:17 am »
One should not be guessing at how it should be crimped: if you want a reliable crimp, you do what the manufacturer says.
Anderson PowerPole (most likely the ones in question) normally use a closed-barrel crimp terminal, and Anderson is crystal clear on how to crimp it: using their tool, with the indents centered along the crimp barrel. (They also list soldering as a non-preferred alternative to crimping. But not both.) And they have pull test specifications.
Are you saying that the retention force of the contact was enough to let a firm yank pull the wire out of the crimp? As in, the contact retention force was higher than the pull-out strength of the crimp? If so, then that means the crimp was nowhere close to properly done. That’s not just not in the ballpark, it’s not even the right city!
Huh? Are you talking about the mating surfaces of the contacts, or about the crimped contact-to-wire interface?
Corrosion of the mating surfaces depends on the application, contact plating, environment, and contact design.
A proper crimp is gastight, so there is absolutely no movement of the wire relative to the contact. If the wire is wiggling within the crimp, then it’s not just not in the ballpark of crimp force, it’s not even in the right country!
A crimp connector that is properly selected for the application, with correct wire and tooling selected, assembled to manufacturer specs, should not become intermittent.
Corrosion within the crimp itself means it wasn’t gastight, which also means crimp force was too low.
I mean, gold embrittlement in solder is a real thing, but only relevant if you were actually finding fractured solder joints.
Mixing contact platings (of the mating surfaces) is a big no-no, at least with respect to gold and tin.
It really doesn’t sound like that company did connectors properly, to be frank!
Only a really poor crimp is improved by adding solder. A good crimp is worsened by doing so.
Online mtwieg
« Reply #31 on: August 20, 2024, 12:11:57 pm »
Here's what NEW wire says:
So 94% vast majority of the wire they deal in is meant to be tinned using solder pot. 5% can't be stripped using solder pot, but are still intended to be soldered after stripping. Only 1% is truly non-solderable, though info on this is really scarce. The example shown in the video has fairly large strands, and few of them. The litz wire I work with as hundreds of very fine strands (40AWG at least). While I haven't seen any vendor categorically state that such wire can't be terminated without solder, I think it's clear that that's their intended process.
Right, that's the "normal" process.
Yeah, it does sound pretty sketchy. The last step should be soldering, in order to relieve stresses and "heal" cracks. Hence my speculation that crimping to the insulated wire and then soldering just once might be a viable process.
Offline bostonman
« Reply #32 on: August 20, 2024, 02:21:29 pm »
Yes, I was talking about corrosion on contact-to-wire.
In most cases, usually I'd ask someone in manufacturing which tool to use. In the case of the company that used Anderson connectors, I don't remember if we even had a tool or just crimped with something else. That company hacked everything they touched.
It was rare my crimps every came out correctly. The wire would birdcage, one strand of wire wouldn't be in, the pin would bend, the pin would be weak and bend as I tried inserting it into the connector, etc...
Maybe I was given the wrong tool, maybe wasn't doing it correctly, etc...
On a side note, slightly different, but just recently I was repairing something with a ribbon cable and the ribbon cable became intermittent over time causing the display to not work. Last year I had a ribbon cable fail in my oscilloscope (to the hard drive).
Offline JohnG
« Reply #33 on: August 20, 2024, 07:11:28 pm »
Agree in general, but sometimes it's unavoidable (like when working with litz wire).
Uhhhhgg, Litz... I wish it were avoidable...
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
Offline tooki
« Reply #34 on: August 26, 2024, 09:08:53 am »
The proper tooling, used according to the instructions, makes it quite hard to mess up a crimp. The things you describe (inconsistency, pins that easily break) sound like you didn’t have the right tooling at all.
One way to reduce birdcaging is to use sharp cable shears to cut wire instead of diagonal cutters or anything dull. Diagonal cutters tend to disturb the stranding far more than shears. Since switching to shears, I’ve found it much easier to crimp without wayward strands.
Not unheard of, but still fairly unusual. Unless you’ve been pulling out the cables by tugging on the cable itself, of course! (Especially bad if the connectors don’t have strain reliefs installed.)
With the display cable, another possibility is that it was a ribbon cable with solid conductors. IDC contacts with solid conductors (including IDC ribbon connectors and punchdown terminals in telecom) are really not good for repeated flexing.
The following users thanked this post: Kjelt
Offline Kjelt
« Reply #35 on: August 26, 2024, 10:22:21 am »
For the visually oriented persons amongst us:
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #36 on: August 26, 2024, 11:35:17 am »
Hah. At least for smaller (pin-sized) litz, I've seen shops just dip the loose end in the pot -- tin the wire, then shove it into the board for a second (and final) soldering step.  Avoid fraying the strands (or I suppose wrap them with a fine strand before dipping) and it works out fine.  Needs a relatively large PTH of course, since some fraying is inevitable.  Usually it's done as part of a lead frame operation: like mounting the e.g. transformer on a mounting base (sheet of FR-4 with holes drilled in it), with blobs of gel epoxy to secure wires on it.  Also an alternative to pinned bobbins, just take the wires out and shove them through holes separately.
Ferrules should be fine, give or take if they're nickel plated I guess, heh.  Disappointed NEWT didn't have anything to say about it.  (I forget if we asked them about ferrules back in the day..)
Would imagine the crimp wire-in-board terminal thingys would do well enough too; I don't know that I would trust those to tin through (clearing out the enamel) if using litz with a fairly ordinary wave soldering process, but if you can spend some time "soaking" them, that would still be fine.  (Customized selective solder, perhaps? Run the wave slower, if everything else is fine with it?)  Pre-tinning of course does nothing, as you'd glom up the snap-in clip parts and not be able to assemble them in the board, or at least any better than as ferrules.
At PPoE, we did industrial (up to sausage-sized) cables by crimping, dribbling in some liquid rosin, then dipping the whole lug, usually with a clean-up step blasting off dross / rough solder with a sanding disc.  Not exactly ideal, but I'm not aware of any that came back to the service department with charred lugs.  (Granted, that might only be a 1/1000s failure rate, hardly exemplary as industrial production is concerned.)
Regarding solder vs. crimp, my understanding is, the crimp has to pinch and stretch -- specifically, not just crush, but to hold in compression, necking down and thus squeezing the strands out lengthwise just a little bit, and the strands spring back against that force, acting to push them back into the crimp, sealing it tight.  It isn't, and doesn't have to be, a cold weld; in fact the strands can move in the crimp, it's not necessarily a problem for the lug and wire to have mismatched thermal expansion for example (but, probably not a good thing if they are very different, lol).
Thus, if we make a very loose crimp (that isn't actually holding tension against the strands), it's better to fill it with solder, because it's not a gas-tight joint, and the solder will make the bond, like a tight-fitting solder pot.  There's nothing wrong with solder pot terminals, in and of themselves.  We have a soldered joint, and all the limitations thereof (creep, fatigue, corrosion).  If you have terminals but no crimper, you can still do them with pliers and a soldering iron in this way -- badly, but you can likely make something that fits wires into a housing, and maybe that's good enough in a pinch.
If we fill a proper crimp with solder, we get the worst of both worlds: the fatigue and creep and corrosion of a soldered joint, without the natural movement (potentially) of the crimp joint; the soldering heat may also relieve some of the stress in the crimp joint, or by melting tin plating (when applicable), change the volume in the crimp, and thus the stress in a more exaggerated manner.
So that's why you don't crimp AND solder.
Then, what about litz?  It's enameled, so there's a three-layer mix in the crimp cross-section: the barrel around the outside, then the matrix of copper and enamel.  This will crimp just fine when cold, but when heated, the enamel breaks down and flows out, relieving stress.  Whether that's bad, depends on how much is relieved: it seems to be enough to fill with solder, but, I mean obviously it's a solder wick, that's not saying a whole lot; possibly it's enough that strands could in fact come loose, but I can't say I've ever extracted strands from a terminal while the solder is molten.  But that might also simply be because the strands are stuffed in there with enough congestion that they can't really pull out
It could also be that not enough stress is relieved by melting the enamel, to loosen it.  We're not talking much strain here (<1%?), but a fair amount of enamel (several percent by diameter?), so I doubt this is the case.  It seems plausible in the tin-plating case though.
But, I think for most applications, they're just not strenuous enough to be a problem: the soldered joint, the vast strand count, and the fact that the cable some inches behind the terminal remains stiff (from the enamel melting together), accounts for most of the strain relief, plus a generous layer of heatshrink does a bit more; and applications may simply be well enough secured, or low vibration, or clean environment, that the stress response (creep/fatigue) and corrosion concerns just don't manifest.  Basically, you aren't usually running litz cables around for general cabling use, they're mostly at the terminals of a component and there's no slack length to couple vibration and handling into heavy flexing.  The situation might be suboptimal in a broader sense, but further optimization may not even be perceptible (in terms of production yield and product quality/reliability).
You definitely don't want to tin AND THEN crimp, as the tinned end will have a substantial fraction of solder inside it, and the whole thing will mush down, getting severely strained and fatigued, while not holding nearly as much springback force as the crimp needs to be sealed against.  The cracked, loose mass may be mechanically pinned (you can't yank it out, maybe even without breaking the wire), but it will be far more susceptible to fatigue and corrosion.  This can be cured (or, probably not completely, but partially perhaps) by remelting the joint after crimping: apply flux, then heat it up; there may be enough excess solder to make a reasonable solder-pot joint, but probably some extra should be added to get a nice fillet.  Plating around the lug ring can be unaffected (or at least, not blobbed up; usually the plating does change on heating, oxidizing or thickening the intermetallic layer), so it bolts down as good as new.
Seven Transistor Labs, LLC
The following users thanked this post: JohnG, mtwieg
Online mtwieg
« Reply #37 on: August 31, 2024, 01:33:06 pm »
Thanks for the input, overall agree with everything.
Ultimately the bottom line for litz wire is that soldering always has to follow crimping (except if you managed to strip the strands without soldering, which is very rarely the case). For larger ring/spade terminals, crimping before tinning should work, possibly even better than tin > crimp > solder for the reasons you mentioned. In my experience, so long as the litz is cut carefully and it's tinned properly by dipping in a solder pot, strands are not disturbed at all; the result looks like you tinned solid wire of the same diameter. But if the strands get frayed (hard to avoid if you tin it with a soldering iron) then that you will end up with a "fat tip" end which is mostly solder, which can make crimping problematic or impossible. Standard approach to that is to just cut the "fat tip" off, but that means you have to tin more wire, burn more insulation, etc...
Offline tooki
« Reply #38 on: August 31, 2024, 02:14:23 pm »
I definitely don’t agree with this conclusion.
Chemical stripping, burning off the insulation in a flame, and hot crimping (where the entire crimp is heated during crimping) are all established methods. I don’t see how trying to tin with solder after crimping would work.
Offline tooki
« Reply #39 on: August 31, 2024, 02:16:38 pm »
I just found this article which says that hot crimping is good down to a single 30AWG strand: https://www.assemblymag.com/articles/89954-hot-crimping-for-joining-magnet-wires
I don’t see any reason why it wouldn’t work with Litz wire composed of 40AWG strands, as long as the total cross-section is at least 30AWG.
The following users thanked this post: T3sl4co1l
Offline T3sl4co1l
« Reply #40 on: August 31, 2024, 03:06:33 pm »
Boy, up to 700°C as well? That surely will "forge weld" (diffusion bond) the joint together -- assuming the charred crud gets out of the way (hah, which would dissolve if it were done on iron, but copper, no chance).  Probably the ramping of pressure and heat at the same time, allows the enamel to melt and largely squeeze away before bonding occurs, and then the crud trapped in the corners doesn't matter too much.
It should very well be able to produce metallurgically welded joints though.  Strain is relieved at that temperature, so there's no tension holding it together; should be able to cut completely through it and not have it fall to bits like a cold crimp would.
Well, "rare" is in the eye of the beholder.  Or the statistician, but no one's claiming statistical data here, so any terms of probability are very loosey-goosey neither-here-nor-there statements of opinion, not fact.
I can say from my experience, chemical stripping has always been met with cringes from anyone who'd have to work with it -- it's slow, messy, toxic, needs chemical storage and handling practices, probably the chemicals aren't cheap either, etc. etc.
I've done it myself, but only as a last resort, and only on small scales -- in particular, I have a few spools of this old (true) enameled wire, that you can only scrape off, it carbonizes on heating, utterly unsolderable.  Whenever I go to use it for litz, it's.... ugh.  My most common solution is to melt the end into molten NaOH + KNO3, which tends to burn off and dissolve the enamel and copper oxides, leaving a bright pink surface that is tinnable.  It's hazardous (molten salts are prone to splattering, and you don't want alkali on your skin let alone more sensitive areas, like a droplet of melt might cost an entire eye), not easy to use, not terribly effective anyway (a better mix, apparatus to melt it in, and procedure, would be fast and effective though), and the conducted heat leaves several inches of cable charred and questionable.
It might be "common" in certain fields (aerospace? winding shops?), but whether that counts as "common" across all of industry, no idea.
As for burning in flame, complete no-go, leaves burnt crud, carbon and copper oxides all around.  Maybe you can scrunch that around, maybe clean it up with some solvents (even if just to get the crud loosened and washed out), but I wouldn't want to rely on a crimp with all that crap involved.  Or maybe there are specific enamels that burn off cleaner than others, but again, are we talking common off-the-shelf stuff here or what, and what are your statistics to support that, etc.
Now I kinda want to try hot crimping myself.  Don't quite think it's going to be as simple as putting a tool and die inside an induction field though...
Regarding soldering, I've found it effective to twist the cable while molten, pinched between the iron and work table.  You can get it to twist together a bit, and this tightens the bundle and squeezes out some solder.  Tedious hand operation, but maybe of interest for one-offs.  (Be careful not to splatter as the wire inevitably slips and bounces as it's twisted and squashed under the iron, and as you lift and reposition it!)
« Last Edit: August 31, 2024, 03:12:29 pm by T3sl4co1l »
Offline KE5FX
    • KE5FX.COM
« Reply #41 on: August 31, 2024, 03:35:37 pm »
The best process in the world is still not a good process if it has to be executed flawlessly, or if it can only be executed well enough by someone who does it all day/every day, or if it can only be executed well enough with a $500+ tool that I don't have.
That's why I still favor soldering over crimping in most cases.  Yes, crimping is better.  No, I don't crimp enough connectors to ever become genuinely good at it.  And I've got some really bad news for those who assume it will always be done properly in a factory or other professional environment.
With PowerPole connectors in particular, the spring tension is both critical and hard to inspect.  I use a lot of them, but I'll never be as big a fan of them as some people are.  Crimping is 99% reliable at best, and soldering is no better because (again) it's all about the springs.
Offline tooki
« Reply #42 on: August 31, 2024, 04:25:36 pm »
Crimping is highly reliable, well over 99%, if done with the right tooling and according to directions!
With the right tools, it takes essentially no practice whatsoever to produce perfect crimps. If one's crimp process is significantly subject to operator experience, there is something deeply flawed with the process!
If you properly match the wire, contact, and tool, and follow the instructions properly (e.g. correct strip length), using the correct first-party tool, then a perfect crimp is practically guaranteed. That's why crimping is actually considered a lower-skill assembly method than soldering.
The problems people run into are that they're mucking around with bad tools, and without any care to matching wire size to the contacts. It's not a process you can just eyeball. It can be done anywhere, as long as you have the right tool, it certainly isn't limited to a factory! (OK, I wouldn't want to crimp contacts for a 1mm pitch connector while riding a city bus. ;) )
I don't entirely disagree with your statement that a process is not good if it demands flawless execution -- rather, it's just a factor that speaks against a process. But in a sense, every process demands skill somewhere, it's just a question of where. Crimping puts the skill in the tool and contact designers and manufacturers; soldering puts it largely in the operator.
I don't think, however, that a process can be called "bad" just because it requires proper tooling for success. By that criterion, most processes are "bad", and many would be "horrifically, unspeakably awful", like semiconductor production, which requires billions of dollars of tooling.
What I just disagree with is people saying "crimping is unreliable" as a blanket statement, when in fact it's only unreliable when done with janky tools.
Spring tension? I don't think any crimp tool in existence relies on actual spring tension to adjust the crimp force. Springs are used in the mechanism, but as far as I know, the actual force adjustment is some kind of limiter or end stop that you move. The springs are just there to return the tool to the open position and to hold some other parts in place.
Offline KE5FX
    • KE5FX.COM
« Reply #43 on: August 31, 2024, 04:38:27 pm »
I'd make the opposite argument.  I was a natural at soldering the minute I picked up an iron as a child, but I still have to read the instructions and practice every time I need to crimp something smaller or more delicate than a PowerPoint connector.
I'm talking about PowerPole connectors specifically here, where hidden springs are used to maintain contact between the mated terminals:
Guess why I felt compelled to X-ray that one...
Offline tooki
« Reply #44 on: August 31, 2024, 04:59:43 pm »
Well, I didn't say training, I said skill. If you were a natural at soldering even as a kid, then you acquired the necessary skill on your own, but the upshot is that you possess the skill. Some people can go through training and still not acquire it.
And some people actually don't have the skill, but think they do, and send out crappy solder joints.
As for needing to practice: that applies to soldering, too! It's perfectly normal to have to get a feel for a particular solder joint in a device, like when soldering ICs and figuring out that certain pins need to be heated longer because they're connected to a ground plane on the other side of the board. The difference is that in soldering, you can in essence experiment with a joint while doing it, so that even your trial joints are part of the finished product. In crimping, you cannot rework a joint.
But as I said, with the right tools, crimping doesn't even really need practicing. The project I did recently with the 100 Micro-Fit contacts was my first time using the tool, and I did a few test crimps, but I actually didn't really need to; every single one came out flawless. I had to spend time adjusting my wire strippers to the precise strip length needed (since I needed a length between two depth stop detents), but that isn't unique to crimping. Soldering also requires the right strip length for the job.
Oh OK, I didn't realize you were talking about the connector itself.
But what does that have to do with crimp vs solder? In PowerPole, both crimped and soldered contacts use the identical housings, so whatever the effects of the spring, they aren't specific to the termination method.
This critique is 100% about the connector design, and not about crimping vs. soldering.
I dunno. The wire on the right seems to be kinda wonky, maybe from being flexed?
What's the answer?
Offline KE5FX
    • KE5FX.COM
« Reply #45 on: August 31, 2024, 05:44:48 pm »
What's the answer?
The contact is OK as long as the connectors are in line with each other, but the spring tension wasn't high enough to keep them together when the connection is flexed a bit.  It's easy to see how that can happen given the ample amount of free space.
The same thing can happen regardless of whether it's crimped or soldered, so it's not useful as a way of arguing for either method.  But since the subject of PowerPole connectors was raised as a possible answer to the OP's question, it's potentially relevant.
One user error that is present is the fact that both leads extend past the crimping areas far enough to touch the shells.  That tends to constrain the ability of the contacts to follow the spring forces to some extent.  I didn't know to watch out for that until I took the X-ray.
Offline tooki
« Reply #46 on: August 31, 2024, 08:21:30 pm »
Well no, actually they weren't. They were discussed tangentially only. OP was not asking for alternatives to Faston-style terminals, only for brand recommendations of such terminals.
Were the contacts in the x-rays the open or closed barrel type? If they're closed barrel, which is what those look like from the silhouette, then that's not the conductor "brush" sticking out, but just the end of the contact. See the photos of both styles in https://powerwerx.com/help/powerpole-assembly-instructions and https://www.qsl.net/lcares/manuals_files/Powerpole-Rev0.pdf
FWIW, the instructions say to strip 5/16" (7.9mm): https://www.andersonpower.com/content/dam/app/ecommerce/product-pdfs/PP-Pak/1s1112.pdf
