Author Topic: Version 8 Project News  (Read 43424 times)
Offline SiliconWizard
Re: Version 8 Project News
« Reply #50 on: February 19, 2024, 06:29:45 am »
What I really wish it had is the ability to store presets for the Plot options.
As it still is, it's utterly annoying: it's much too easy to screw up a setting when generating CAM files and not notice. This is aggravated by the fact that the settings are common for the different output formats you can select.
So, a typical use case (and major annoyance):
- You want to plot one or more layers to DXF,
- Then later you generate Gerber files. The same settings as what you set for the DXF are selected, and they have 99% chances of not being the same as you want for Gerbers.
- Horrific.
Looks like a small thing, but a really annoying issue. I don't know if they added it in v8. Tell me they did. :palm:
« Reply #51 on: February 19, 2024, 08:19:47 am »
I'd be curious to see what Valgrind finds with Firefox... :-DD
Isn't Firefox written in Rust these days? I'm not aware of Valgrind support for Rust.
In what dimension exactly? :-DD
According to this: https://4e6.github.io/firefox-lang-stats/
it's about 11% of Rust overall. I don't even know how one could think that such a monster as Firefox could be entirely rewritten in another language in less than 20 years and without breaking most of it.
As to Valgrind and Rust, yes sir: https://nnethercote.github.io/2022/01/05/rust-and-valgrind.html
Offline shapirus
  • Country: ua
« Reply #52 on: February 19, 2024, 08:39:03 am »
- The RC3 is still a bit crashy
Crashes are typically considered high priority issues. If you have a reproducible crash scenario, don't hesitate to open a new issue at https://gitlab.com/kicad/code/kicad/-/issues.
Offline MitjaN
  • Country: si
« Reply #53 on: February 19, 2024, 07:46:19 pm »
Pin swapping i see it to be more difficult, but in say microcontroller projects, for anything that isn't strictly microcontroller like programming/reset circuitry/LEDs, i usually attach a label to a pin, and when i have to move it i move the label (or swap two labels with Shift+B) and presto.
For Stub swapping (https://gitlab.com/kicad/code/kicad/-/issues/16898) there is a plugin available. It is a bit awkward as schematics has to be closed and it generates quite significant schematics diff. But it might be useful for some.
