What I really wish it had is the ability to store presets for the Plot options.
As it still is, it's utterly annoying: it's much too easy to screw up a setting when generating CAM files and not notice. This is aggravated by the fact that the settings are common for the different output formats you can select.
So, a typical use case (and major annoyance):
- You want to plot one or more layers to DXF,
- Then later you generate Gerber files. The same settings as what you set for the DXF are selected, and they have 99% chances of not being the same as you want for Gerbers.
- Horrific.
Looks like a small thing, but a really annoying issue. I don't know if they added it in v8. Tell me they did.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
