In Diptrace, I've gotten used to the idea of "net ports". They're one pin components you can make, and the idea is that you drop it on your schematic in a convenient place like any other component (a resistor for example, or even better a ground symbol), and attach nets to it. So for example, I can make a net port named "VCC", and whenever I need to attach something to VCC I can simply drop the net port there, hook it up and voila. Really neatens up a schematic. I guess it's essentially just naming the net, and identically named nets get attached to each other, but it does it visually and without risk of typo.
LTSpice has a similar thing. I think they have a component called a net label, or something like that, that essentially functions exactly like the Diptrace Net Port.
Is there any equivalent way of doing this in KiCad?
Thanks!
