Author Topic: Seeking PCB Designer to work on an existing PCB layout to make some changes  (Read 5062 times)
Offline nickCRTopic starter
Am looking for a PCB designer to help me make some changes to a PCB layout.
Had a PCB layout completed and ordered it from JLCPCB, once in hand realized there were some issues and needed some changes to the unit. The person we had originally hired through Upwork is no longer available and would like to find someone else that could help us with the changes.
Looking to pay $40-$70 USD / hr to help with this task.
Anyone looking for some freelance work?
Offline Smokey
  • Not An Expert
you should say what CAD package was used in the design.
Offline mikeselectricstuff
    • Mike's Electric Stuff
And whether you have the source files, or just the Gerbers
Day Job: Mostly LEDs
Fair enough. The project was created in KiCAD and yes I have the source files.
Also worth noting some additional information:
ESP32 unit with 7 IO ports being used;
4 are for sensors
1 is an RGB LED
1 is for turning on/off 12V to external device
Will require an NDA agreement to be signed before we initiate work.
Would really prefer the person we work with to be in Canada or USA.
Thank you in advance!
« Last Edit: April 19, 2024, 01:01:49 am by nickCR »
The following users thanked this post: YTusername
Offline alpelectronics
Pm sent.
Offline ZGoode
  • Grad student by day, equipment nerd also by day
Assuming you haven't found anyone yet, I can send you a PM.  I have experience in both eCAD design/manufacturing and the ESP32
Offline pi
Very happy to help with the pcb layout @nickCR if the gig is still available.
I have sent you a PM.
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
if you still need this, I can join. I designed products which sells nice: www.thundertronics.net
Offline Sagar
  • Country: in
I have designed some Boards using ESP32 and ESP8266, I am an electronics science student and freelancer on hardware hubs (instructables, hackster, hackaday). If any help required then let me know I am doing freelancing also.
