It does look a great multimeter for the price.
The one negative I could see is for current ranges of 500mA and below, it has a strangely high burden voltage.
From the Amprobe data sheet, the burden voltage is 1.65V full scale on the 500mA range and 0.75V on the 5mA range full scale.
On the 5A range however, you can resolve down to 1mA, and 500mA of current would cause a 15mV burden current and so most of the time, you could live with using the 5A range for measuring power supply current.
Richard.
