Hello, bit of a digital scope newb here!
I have the Rigol DS1052E (not modded) and i am looking at chaotic attractors, which are running at 0.1- 1 hz cycle time.
I am using XY mode.
at that low frequency, the scope only shows the trace less than 20% of the time, so basically i just get a dotted line. quite useless! adjusting the timebase just changes the length of the dots.
on my analog scope it is also useless, because it has low persistence, you cant see the trace at that low speed.
I would have though displaying a slowly moving voltage would be EASIER, not harder, anyways what causes it, and what specification would i look at in a different Digital scope so that would not happen?
(also i would like variable persistence, rather than just OFF and ON.)
Thanks!
