Author Topic: FLUKE 87-5 DMM Accessory..Made In Greece - Greek Patent !!  (Read 6182 times)
Set of pictures .  8)  By Kiriakos Triantafillou  Volos - Greece .
« Last Edit: September 26, 2011, 12:59:39 am by Kiriakos-GR »
Re: FLUKE 87-5 DMM Accessory..Made In Greece - Greek Patent !!
« Reply #1 on: April 28, 2010, 09:03:13 pm »
If any one shares my fear that the New holster of the 87-5  (87V)  ,
that it looks and feels like to be ready to flip over, due poor design ...
By looking the above pictures , you can be aware of,  what you need to do as correction.
The plastic part , its part of one machine that is used to cut grass , the ones with the rotating string .
Actually its the round shield of it .
Its from the hardest unbreakable plastic .
Found it accidentally, same color as the Fluke, the transformation - construction took as two hours,
but it worthed it ..
The DMM become sturdy as a Rock ... this patent has zero impact as damaging factor,
the holster clips on it , with out pressure or force ,
and the only must do , are the slot to have an accurate length, with minimum free play.
Now you can congratulate me.  ;D
Dave I do not have a second one  ;)
« Last Edit: April 28, 2010, 09:05:41 pm by Kiriakos-GR »
« Reply #2 on: April 28, 2010, 09:52:23 pm »
Great job!  You take very precise photos.
« Reply #3 on: April 06, 2011, 01:18:06 pm »
If any one has any similar ideas , post them here.  :)
Alex
« Reply #4 on: April 06, 2011, 01:27:25 pm »
Good work Kyriako!
Another idea would be to have at the lower end of the back stand two retractable pins that open up to form a similar stand that Kyriakos came up with. This will allow this accessory to be part of the DMM's stand.
Another alternative would be two have two layers of back stand mounted on a pivot point. To deploy the DMM you lift the back stand, then slide the two layers apart to form an inverted Y.
Alex
« Reply #5 on: April 06, 2011, 01:29:58 pm »
no cant. its patented already. look at the topic!  :D
« Reply #6 on: April 06, 2011, 01:44:35 pm »
Well Alex , I would prefer to see something all ready made.  ( pictures)  ;)
You you you you ......   :D
I had offer my idea directly to Fluke , as gift for their positive response ,
on my issue ..
Who knows , possibly it can become this accessory as another freeby in the Fluke boxes in the future.  ;)
« Last Edit: April 06, 2011, 01:46:06 pm by Kiriakos-GR »
Alex
« Reply #7 on: April 06, 2011, 01:50:04 pm »
Yeah yeah, but that would require designing and CNC-ing parts. It's the same principle as your idea, just integrated on the back stand.
« Reply #8 on: September 26, 2011, 01:04:41 am »
All pictures replaced with healthy ones, the original files was  damaged from the latest server update.
