Out of curiosity I looked at the firmware update.
It is a *.GEL file that you can open with 7ZIP without problem.
The file within can then be extracted again with 7ZIP and you get the folder structure of the whole update file.
The update routine includes this folder with the update scripts:
Directory of DHO800_DHO900(Software)Update\Root\shell
13/09/2023 17:44 <DIR> .
13/09/2023 17:08 <DIR> ..
29/03/2023 09:37 512 bootApp.sh
29/03/2023 09:37 659 copy_logs_to_udisk.sh
20/06/2023 12:47 8,079 do_extract.sh
08/06/2023 03:46 1,798 do_update.sh
29/03/2023 09:37 645 force_update_gel.sh
29/03/2023 09:37 1,027 load_pcie.sh
20/06/2023 12:47 1,427 reload_fpga.sh
05/07/2023 08:16 97 restartScope.sh
20/06/2023 12:47 5,362 start_rigol_app.sh
9 File(s) 19,606 bytes
The main app is the Sparow.apk. Looking at it with a HEX-Editor, I found this:
License file detected
License invalid. Remaining attempts: 1
License invalid. Remaining attempts: 2
License invalid. Remaining attempts: 3
License invalid. Remaining attempts: 4
License invalid. Remaining attempts: 5
License invalid. Remaining attempts: 6
License invalid. Remaining attempts: 7
License invalid. Remaining attempts: 8
License invalid. Remaining attempts: 9
This function requires the following license:
Also, it seems that the licenses are stored in "LICENSE.txt".
It should be possible to edit "copy_logs_to_udisk.sh":
#!/system/bin/bash
echo "...... ifconfig ......"
ifconfig
udisk_mount_dir=$(ls -d1 /mnt/media_rw/* 2> /dev/null | head -n 1)
if [[ x"${udisk_mount_dir}" == x"" || ! -d ${udisk_mount_dir} ]]; then
echo "Does not exist U-Disk !"
exit 2
fi
target_log_dir=${udisk_mount_dir}/$(date "+%Y.%m.%d_%H.%M.%S")
# target_log_dir=/data/UserData/logs_for_debug/$(date "+%Y.%m.%d_%H.%M.%S")
echo mkdir -p ${target_log_dir}
echo cp -r /data/logs/tools_log ${target_log_dir}
# chown -R system:system /data/UserData/logs_for_debug
rm -f ${udisk_mount_dir}/fetch_sparrow_logs.txt
sync
In order to add a line like
cp -r /data ${target_log_dir}
The goal is to copy the whole data folder (and its sub-folders) to the attached USB disk. This might be the wrong folder, but with a bit of trial & error one should be able to get to see the LICENSE.txt file. I wonder if the options are in plain text...
Disclaimer: I don't own this device and I am not looking forward to buy one (I have the DS1054Z which is more than I will ever need). These are just my thoughts and ideas, they might break you brand new device.
