Author Topic: How to take apart Rigol DS1052E (with Pictures)  (Read 10203 times)
Offline Zyvek
Re: How to take apart Rigol DS1052E (with Pictures)
« Reply #1 on: December 29, 2010, 08:19:02 pm »
Thanks. Strangely enough I couldn't view your album unless I logged out of my Google account.
-Z
Offline wd5gnrTopic starter
« Reply #2 on: December 29, 2010, 08:27:51 pm »
That is strange. I have them shared public. If everyone else has problems, I can find another home for them.
« Reply #3 on: December 30, 2010, 03:36:05 am »
i can see the slideshow pics, but... flash? kinda dont like it very much, how about just put those pics here or in you web hotsolder? in plain (non flash) format?
« Last Edit: December 30, 2010, 03:38:09 am by shafri »
« Reply #4 on: December 30, 2010, 04:05:58 am »
Its just Picasa web album which is easy to post. If you don't like flash try this:
http://picasaweb.google.com/lh/sredir?uname=109721484330599851932&target=ALBUM&id=5556172867435670145&authkey=Gv1sRgCMnJtMbRk6yn1AE&feat=email
That should be just flat I think.
Offline Simon
« Reply #6 on: December 30, 2010, 10:02:31 pm »
nice photos, to be honest i like to see it as a page with instructions and photos.
Offline orbiter
  • -0 Resistance is Futile
« Reply #7 on: January 01, 2011, 12:40:08 pm »
Good job wd5 and thanks for posting the pics.
Is your scope working ok again now?
« Last Edit: January 01, 2011, 06:29:35 pm by orbiter »
« Reply #8 on: January 01, 2011, 04:40:17 pm »
Yes. The scope had been very hard to move the trigger level (only moved up and very jerky). Then later it quit moving at all. Replacing the encoder got it moving up again. Replacing a diode under the encoder got it moving perfect again. The only downside is the new encoder has detents.
HOWEVER, I must applaud Rigol here. I wrote asking them what kind of encoder it was -- explained that the scope worked well enough I didn't want to send it in for service and I had already opened it up and broke the seal. They verified I had bought from a US distributor (I live in the US) and just sent me a new UI board. Naturally, it arrived 2 days after I fixed the scope. I haven't decided if I'm going to open the thing back up and replace the board or just hang on to it for now since I am actually in the middle of using the scope for something. But very nice service from Rigol.
Offline orbiter
« Reply #9 on: January 01, 2011, 06:35:00 pm »
It's great when companies don't just fob you off and and actually try to help out. Rigol did well here.
Congrats on fixing your scope yourself.
Offline Simon
« Reply #10 on: January 01, 2011, 06:38:33 pm »
I'm surprised to be honest, but then judging by the encoder quality it sounds like a fixed part is better than another poor quality replacement. Can we have the encoder model please ? that way we can all get correct replacement when we need them
« Reply #11 on: January 01, 2011, 07:22:52 pm »
I don't have the real encoder model number. Its an ALPS. The replacement I used is: http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=987-1195-ND&x=0&y=0
Fits perfect, but has detents.
Offline Simon
« Reply #12 on: January 01, 2011, 07:56:28 pm »
what are detents ?
Offline orbiter
« Reply #13 on: January 01, 2011, 09:06:16 pm »
what are detents ?
It's just a name given to a type of basic locking mechanism, It could be like a lug or dog tooth type thing which helps lock something in place or prevents movement.
« Last Edit: January 01, 2011, 09:08:50 pm by orbiter »
Offline Zyvek
« Reply #14 on: January 01, 2011, 09:46:46 pm »
Detents give a control the physical 'click' felt when turning the knob....also can be used to feel when a stereo balance knob (or fader) is in the center or neutral position..
« Last Edit: January 01, 2011, 09:54:17 pm by Zyvek »
-Z
« Reply #15 on: January 02, 2011, 01:19:35 am »
The two scale knobs have detents. The 4 "little" knobs on the scope don't. Now my trigger level knob has detents unless I swap the board out.
