Author Topic: Portable calibrator (UK ) - MICRO CAL 1030  (Read 7272 times)
« on: August 11, 2010, 04:52:13 pm »
• 10mV, 100mV, 1V ranges
• 10mA, 100mA ranges
• 0.1% accuracy
• 0 - 8V available
• Precision 10-turn dial
• Battery Powered 9V PP3
• Battery level indicator
Description:
The 1030 is a compact, low cost, portable voltage and current calibrator for general purpose signal injection. It is suitable for voltage and current loop signal simulation as well as thermocouple simulation. The precision 10-turn dial provides a conventional feel to setting the output with a setting resolution of 1 part in a 1000 (0.1%)
PDF http://www.timeelectronics.com/download/1030v1c.pdf
Comments :
An very nice device , it does all that it promises , I have only one small complain,
the mode switch needs some force to move around .
I had add also the soft pads at the bottom ,  originally comes with an soft leather black case,
that I have it too , but on the bench , the extra soft pads helps it allot.
But, I do not deserve to nag , got it from ebay  for  1/20  of the street price (547,47 EUR ) ,
an lady was cleaning the warehouse of her ex-husband ..  ;)
« Last Edit: August 11, 2010, 04:59:30 pm by Kiriakos-GR »
Offline Richard W.
Re: Portable calibrator (UK ) - MICRO CAL 1030
« Reply #1 on: January 19, 2011, 06:56:24 pm »
Is it possible to get a view of the inside?
I am curious about the reference-voltage chip inside.
(Don't turn it on, take it apart  ;D )
« Reply #2 on: January 19, 2011, 08:06:30 pm »
I had open it , at the time that I got it , so to replace the 9V battery clip with new.
In order to look  the parts on the PCB  you have to totally take it apart= strip it ( all the front panel ).
And no matter how enjoyable could be , I am afraid to do it , on anything that has the label of "reference"  on it .  ;)
Offline Richard W.
« Reply #3 on: January 19, 2011, 08:37:08 pm »
In this case it's of course better not to take it apart.
I also wouldn't dare to open my Gossen Metrawatt  ;)
Offline Mark Hennessy
    • My electronics and audio website
« Reply #4 on: May 14, 2016, 11:51:00 am »
I took mine apart :)
http://www.markhennessy.co.uk/time_electronics_1030_microcal/
It's very easy - you simply remove the knob from the rotary switch and undo the nut. Everything else stays in place.
The unit is based around the LM10. There is a number of selected resistors in there, plus 2 pre-set adjustments. Based on my testing, I'd say the specifications are pretty conservative. Overall, I like it - I'm surprised at how much I've used it - far more practical day-to-day than those fixed voltage references (which are usually more precise, but for a specific use only).
In addition, Time Electronics are very helpful  :-+
Hope this helps,
Mark
The following users thanked this post: nikifena, Docholiday
