Thanks for showing the JBC running over temp in your latest video. Shows how easily set temp, actual temp and tip affects the results.
Any thoughts on how best to show the actual tip temperature on other stations? I'm struggling to think how to reliably show the difference between systems.
I should probably start a separate thread for discussing all the different soldering stations.
I don't think some overshoot is a big deal, as that doesn't really translate into overshoot into the device being soldered.
For me the big thing is the thermal capacity, or how much it drops in temp for a given load.
I do comparison tests of this by heating up a copper clad board (doesn't matter what it is, so long as you standardise) and setting the minimum temperature at which is melts. The irons that melts at the lower temp, wins.
Pace didn't like this method and criticised me for it as being "non-realistic", but when I pushed them to come up with a better method for comparison, they couldn't.
Of course it's not supposed to be a realistic test, as you
can't compare irons when they are comfortably within their thermal capacity range at normal soldering temps. You have to lower the temp to see where the limit is.
