Author Topic: Windows XP, how to clean register from unused USB devices?  (Read 638 times)
Offline DiTBhoTopic starter
« on: June 04, 2022, 01:45:25 pm »
so, I have to use a USB-sniffer on a Windows XP machine in order to understand how an abandoned USB device works.
But before attaching the USB-sniffer I need to clean out all the unused but registered USB-devices.
The list is toooooooooooooooooooo long. You attache an iPod? Windows XP registers its VID:PID somewhere.
How to clean?  :o :o :o
Online Ian.M
Re: Windows XP, how to clean register from unused USB devices?
« Reply #1 on: June 04, 2022, 01:57:14 pm »
Nirsoft USBDeview
https://www.nirsoft.net/utils/usb_devices_view.html
You can sort by connected status, then select multiple devices by shift or ctrl clicking and bulk uninstall them.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #2 on: June 04, 2022, 03:37:21 pm »
There exists GhostBuster to delete all unplugged USB devices.
https://bitbucket.org/wvd-vegt/ghostbuster/src/master/
Especially helpful when you've run out of all 256 COM ports.
The following users thanked this post: coromonadalix, DiTBho
Offline fordem
  • Country: gy
« Reply #3 on: June 07, 2022, 05:53:37 pm »
At a command prompt enter the following line
set devmgr_show_nonpresent_devices=1
devmgmt.msc
The device manager applet will open, click the view menu tab and select show hidden devices.
Scroll down to the USB devices and delete anything/everything that has been "greyed out"
