how many computers still have an optical drive ?
at least there are 3 here..
yes, old ones you bought 5 year ago. Go to a store and try to find a laptop with an optical drive. If you need a mac : good luck ..
As for dvd drives : if you never use them the lenses collect dust and a kind of haze develops over it. most lenses are polycarbonate.
I ditched all that stuff. floppies, optical disks , usb sticks...
Two nas boxes that mirror each other , in different geographical locations, unencrypted drives , standard EXT-2 format , clone in the nas + clone between nas) and an encrypted backup subset stored at a cloud provider.
cloning is not automatic. we don't want a good file to be overwritten by a corrupted newer version of the file. I use a tool called ViceVersa and keep multiple versions (similar to apple timemachine. Viceversa has very fine control of the archiving options).
Verified i can pull a drive, hook it to a computer esata (or usb<>sata) port and access it without problems. No jbod or raid , that too is nothing but trouble in case of a disaster. Often you need the exact raid controller to be able to rebuild. Fat good that stack of drives does you if the disk structure is unreadable due to controller differences.
