There are some manually steps needed to properly set the power management for nVidia when the proprietary drivers are used in Linux (Kubuntu 20.04 LTS, nVidia v450).
The proprietary nVidia drivers can be installed in Ubuntu straight from GUI, but these steps are not performed, I don't know why not:
https://download.nvidia.com/XFree86/Linux-x86_64/455.28/README/powermanagement.html#SystemdConfigur74e29The only thing different was the location of the files to install, instead of the '/usr/share/doc/NVIDIA_GLX-1.0/samples/systemd/' used in the nVidia webpages, mine were to be found in '/usr/share/doc/nvidia-driver-450' (for future versions, search for the 'nvidia-sleep.sh' file to find the directory).
After I executed the steps from that page, there are no more video tearing or image artifact after waking from standby. I am using Suspend to RAM (STR, or S3). Should work for Hibernate (S4), too, but I didn't test that because I never use hibernate.
sudo find /usr/share/ | grep -i nvidia-sleep
# and found /usr/share/doc/nvidia-driver-450/nvidia-sleep.sh
cd /usr/share/doc/nvidia-driver-450/
sudo install ./nvidia-suspend.service /etc/systemd/system
sudo install ./nvidia-hibernate.service /etc/systemd/system
sudo install ./nvidia-resume.service /etc/systemd/system
sudo install ./nvidia /lib/systemd/system-sleep
sudo install ./nvidia-sleep.sh /usr/bin
sudo systemctl enable nvidia-suspend.service
sudo systemctl enable nvidia-hibernate.service
sudo systemctl enable nvidia-resume.service
sudo reboot
