(As a post-not-mortem info - don't check with a tester. Low voltage modules are not uncommon, the tester actually might kill it. Unless there are burn marks on it, I'd consider it safe to test within the computer. Install, boot up with a Memtest USB stick, let it run for a day. If that test is passed, the module is very likely good.)
