Author Topic: keeping code running in main form when new forms are opened in c#  (Read 469 times)
Offline snarkysparkyTopic starter
In my main form I have a timer that is doing periodic work that I want to keep happening when a new form is opened.
The work involves checking a TCP listener for connections as well as other non GUI communicating with hardware.
If a modal form is opened does this timer in the parent form keep running even though the parent form GUI is inactive ?
Thanks
Online IanB
Re: keeping code running in main form when new forms are opened in c#
« Reply #1 on: April 08, 2022, 02:33:06 pm »
Why don't you test it?
Arrange for the timer to write periodic messages out to the console window (or debug window), and then watch to see if these messages keep coming while the modal form is open.
« Reply #2 on: April 08, 2022, 02:39:16 pm »
I have tested.  Timer does keep going.  But I really really would like to know that this is the expected result and not just a fluke.
Thanks
Offline zzattack
« Reply #3 on: April 08, 2022, 02:50:41 pm »
Opening a modal form on top of another one does not block the obscured one's message loop, so yes this is as expected.
The following users thanked this post: snarkysparky
