What for though?
what(what(what(x))), what(what(what(for though?)))
anyway, somehow solved myself
I still don't know which company made(?)/still makes(?) those viewfinders, but a found other four decommissioned x-ray machines, teared down, got a written permission to take all the viewfinders.
so I have two 1" mini screens with all the optics already made and assembled, and the input is XVGA@60Hz.
Excellent!
I think I'll build some polycarbonate supports to mount two viewfinders on a VR-structure; here, I will probably buy something cheap (~50-100 euro) on Amazon, teardown it, and hack it to reuse the frame-structure and make my version, then I'll move on to assembling something wearable, with
- Power(1) + VGA, right channel, 9 wires, { R, G, B, H, V, GND, 12V, /en, GND }
- Power(1) + VGA, left channel, 9 wires, { R, G, B, H, V, GND, 12V, /en, GND }
Then I will have to deal with stereoscopic vision, that is, build a VGA splitter that does not limit itself to replicating the input stream onto two output streams, but which translates the pixels horizontally enough to satisfy the stereoscopic vision so as not to be perceived "annoyance" to those wearing the visor
(1) during the teardown, I found the viewfinder used in the x-ray machine has a power enable, which is a common TTL input, the "/en" pin. 5V, negative logic.
No problem, short it to GND, and the viewfinder will be always on.
