The HP Z-series are good, but power hogs.
Not sure whether that's important to you or not.
umm, 1Kwatt is the max I can supply.
I've already wondered why HP tends to make things so
power hungry when I picked up my HP-PARISC workstation(1) and found that with GNU/Linux it draws up to ~ 150 Watts(2) even though there are nothing but common demons waiting for a connect, i.e. { sshd , telenetd, tftpd, nfsd, ... } but nothing that is actively but silently compiling inside a tmux/screen.
So, when Top says that both the CPU and IO loads are low, indeed you immediately get when Gcc, Ninja and distcc are running because as soon as you try to invoke "emerge" to compile something serious (i.e. "emerge cmake", which eats up to 1Gbyte of ram, and takes 2 hours to compile), the wattmeter says that the power consumption has risen to 500 Watts, value in the measurement window of the wattmeter, which then goes back down to ~150Watt as soon as it's finished
HP ...
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
(2) with
- 1 CPU, PA-RISC-v2@~550Mhz
- 8Gbyte ram (HP custom, I think they are ~DDR1)
- two SCSI HDDs@12K-rpm (Raptors)
- two PCI-fiberoptic cards
- one PCI-Wifi card
- one PCI-Matrox MillennumI, MDA
- one PCI-Adaptec-SCSI-lvd card
