Printing use small dumb HP printers, and for scanning SANE and some old scanners, that were tossed, because the one Canon would not work past Win98SE, and the HP because HP no longer supplied drivers past XP for it. But both work perfectly under Linux.
Now if only the developers could fix Glabel........ Workaround is to boot the old original Win7 home, and use Zebra Designer in there. About the only time i actually boot the original OS on that laptop, the last major use was to watch a webinar with the late Jerry Pournelle that was run with GotoMeeting. And with Larry Niven as the admin.....
