Author Topic: HP All In one - Power LED blinking 7 times  (Read 11184 times)
Offline 2XTopic starter
  • Country: gr
« on: May 30, 2020, 08:28:09 pm »
Hello I have the motherboard from an "HP All-in-One - 22-b000nv". I remove the motherboard from the HP PC case in order to put the motherboard in a case that I designed. The power LED blinking 7 times
repetitevely with a small pause. The HDD (is NEW - empty/formated) motor don't start to roll at all and the HDMI out is dead. Original the PC had a screen which connected at the motherboard directly which is the only that is not connected.
« Last Edit: May 30, 2020, 08:30:38 pm by 2X »
Offline Syntax Error
Re: HP All In one - Power LED blinking 7 times
« Reply #1 on: May 30, 2020, 09:01:33 pm »
Is your startup problem covered by any of these Hp BIOS/HW error codes?
HP Desktop PCs - Computer Does Not Start and Emits an LED or Beep Code : https://support.hp.com/gb-en/document/bph07107
  • Country: gr
« Reply #2 on: May 30, 2020, 10:04:15 pm »
It doesn't display bios letters at all.
« Reply #3 on: May 30, 2020, 11:02:55 pm »
Is the jumper on the 10 pin feature connector ( above the word '2nd FAN' ) set correctly?
  • Country: gr
« Reply #4 on: May 30, 2020, 11:38:08 pm »
The jumper connects the pins 9 & 10.
  • Country: gr
« Reply #5 on: June 02, 2020, 07:19:00 pm »
Finally I found that this HP model enebles the HDMI out after the windows loading and this can't changed from the bios.
Offline ruftas
  • Country: ke
« Reply #6 on: December 14, 2020, 08:32:02 am »
There is a cable that runs from the motherboard to the SCREEN. Disconnect it from the Screen. but leave it on the MOTHERBOARD. Assuming you dont need to use the screen. The cable is between webcam port and the WIFI card on my machine.
