Author Topic: CloneZilla - SATA SSD to USB 3 SSD - cloned like lightning!  (Read 432 times)
Offline etiTopic starter
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« on: March 28, 2023, 01:09:14 am »
Hi.
Bought a mint ThinkPad L540 from a wholesaler. The supplied SSD is a 192GB Samsung (Windows 11) with only 40GB used space. I fired up 'Ole Faithful, AKA "CloneZilla", connected my new Integral 480GB SSD via a USB 3 to SATA adapter, expecting the clone (192GB ---> 480GB) to take 15-20 mins... but it completed in what felt like a heartbeat 4-5 mins! It even did the proportional resize operation (to allow for the larger target SSD) in that time.
All works perfectly, no disk checking, no errors, Windows boots and I am back in my OS where I was on the older drive. Is this normal? I know SSD to SSD, even over USB 3, is fast, but this was INSAAAAAAANE!  :D :-+
Offline mapleLC
Re: CloneZilla - SATA SSD to USB 3 SSD - cloned like lightning!
« Reply #1 on: March 28, 2023, 09:29:30 pm »
Sounds normal.  It's a great piece of software with a stupid name, used correctly it's remarkably stable.
I was sorting thru old utilities the other day and I found DebugView by sysinternals that was bought by Mikrosoft way back.  It's the most useful windows debugging tool I have ever found. One of it's best uses is being able to open it on a production box and get a snapshot of the traces on the system.  You can narrow it to only what you are debugging on, or even capture kernel events.  It's amazing how many sofware engineers I worked with that had never heard of it.
To use it, just embed debug.trace or equivalent statements and they will be outputted on debugview, just set capture > globalwin32.  It comes in most handy when you are testing end to end communications that cannot be paused for any form of step thru debugging.  Here you can get a complete output of trace statements as your code executes real time.
https://learn.microsoft.com/en-us/sysinternals/downloads/debugview
