I converted a Zotac GT640 2GB into a Grid K1. All seems to be recognized as supposed (Grid K1). I am able to use the card in XenServer as Passthhrough, however I am unable to use the vGPU capabilities.
HereĀ“s what I did so far:
- Installed a XenServer 6.2 Hypervisor.
- Upgraded it with SP1 and added the following HotFixes: SP1009 and SP1011
- Installed NVIDIA-vgx-xenserver-6.2-340.57.i386.rpm
- Disabled the "64-bit Memory Mapped I/O" in BIOS and Restarted
I am able to see the virtual GPUs in XenCenter (and I am able to add them to the VMs), however, I cannot boot them since I always get this error in messages log:
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: vmiop-env: guest_max_gpfn:0x10efff
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: pluginconfig: /usr/share/nvidia/vgx/grid_k120q.conf,gpu-pci-id=0000:01:00.0
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: Loading Plugin0: libnvidia-vgx
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: gpu-pci-id : 0000:01:00.0
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: vgpu_type : quadro
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: Framebuffer: 0x1A000000
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: Virtual Device Id: 0x0FF7:0x109C
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: ######## vGPU Manager Information: ########
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: Driver Version: 340.57
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: notice: VGX Version: 1.3
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: error: vGPU is supported only on VGX capable boards
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: error: Initialization: unknown error 1
Dec 10 12:43:14 xen fe: vgpu-6[12593]: vmiop_log: error: vmiope_process_configuration: plugin registration error
Has anybody been able to successfully virtualize a converted Grid K1 GPU in XenServer?
Some more information:
[root@xen ~]# lsmod | grep nvidia
nvidia 9522927 8
i2c_core 20294 2 nvidia,i2c_i801
[root@xen ~]# nvidia-smi
Wed Dec 10 14:53:19 2014
| NVIDIA-SMI 340.57 Driver Version: 340.57 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GRID K1 On | 0000:01:00.0 N/A | N/A |
| 30% 34C P8 N/A / N/A | 8MiB / 2047MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
