Proxmox= done
vm= done (Windows 10 is running)
change to pcie Passthrough = failed (No IOMMU detected, please activate it.See Documentation for further information.)
In bios is only one place to change to vt-d on and off thats all. I think it does not work with my laptop HP Pavilion 17-ab303ng
i test it one more time i think i do something wrong....!
Laptops don't have a very high success rate with VT-D so I recommend using a desktop. If you still want GPU virtualization, you can try out the new GPU partitioning on windows 10 with the reddit guide that I linked in the earlier post.
Ok. After Proxmox dismis then i test windows variant.... but i have good news
root@pve:~# dmesg |grep -e DMAR -e IOMMU -e AMD-Vi
[ 0.007631] ACPI: DMAR 0x000000007AFA9000 0000CC (v01 HPQOEM 845E 00000001 HP 00040000)
[ 0.040937] DMAR: IOMMU enabled
[ 0.084938] DMAR: Host address width 39
[ 0.084939] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.084943] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.084944] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.084947] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.084947] DMAR: RMRR base: 0x0000007a734000 end: 0x0000007a753fff
[ 0.084948] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[ 0.084949] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[ 0.084950] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.084951] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.084951] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.084952] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.086408] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 0.939698] DMAR: ACPI device "device:7e" under DMAR at fed91000 as 00:15.0
[ 0.939708] DMAR: No ATSR found
[ 0.939733] DMAR: dmar0: Using Queued invalidation
[ 0.939735] DMAR: dmar1: Using Queued invalidation
[ 0.948245] DMAR: Intel(R) Virtualization Technology for Directed I/O
iommu is running... stay tuned
"If you still want GPU virtualization" i want that my graficscard gf1070 transfors to a quadro p1000 vbios
