First of all, a big thanks to anyone who contributed: gnif, verybigbadboy, and all the others I forgot to mention
![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
I'm trying to convert a GTX780 to a Tesla K20 which have the following device IDs:
According to the resistor values that were discovered so far, this would suggest that I would have to find a 5K and a 25K resistor and change them both to 15K since they are both digits are in the 0-7 range. I found the EEPROM and measured the values of the resistors around it. You can find the results below:
![](http://vps1931.directvps.nl/GTX780-1.jpg)
As you can see, I found a 5K resistor which I removed and replaced it with a multi-turn 50K pot which I set to 15K. Unfortunately, this did nothing as the device ID still remains 0x1004 whereas I expected it to be 0x1024. There are two 4.7K resistors at the back of the board and other than that there are no 5K resistors on the board. Either NVIDIA changed the way the device ID is determined, or they changed the values, or there is a simple resistor divider action going on.
Before I go and change the 25K resistor, I want to make sure that I can change the 3rd digit from 0 to 2. I did try to flash a K20 ROM onto the EEPROM, but it is still recognized as a GTX780. Strangely enough, with the K20 ROM, the nvidia-smi tool reports that the board supposedly has 6GB of RAM instead of the actual 3GB. Any ideas or suggestions?
EDIT: I will be updating the image when I discover any new values/paths.
